嗨,上周我买了一个7英寸的显示器与PIC32 MZ控制器接口,我使用以下组件,PIC32 MZ2048 EF144控制器运行在200兆赫,PICTHOP加爱普生S1D13517板,168至132引脚连接器,7英寸定制设计板与PICTWEN板(引脚是适当的)接口,但问题是当程序被加载时,它开始显示红色屏幕,绿色屏幕,蓝色屏幕黑白,同样的事情会重复。我试图调试从最后一个,我无法检测到的问题。我检查了数据管脚和其他逻辑引脚,如帧、VSYNC、HSYNC所有信号都会正常,请帮我纠正这个问题。注意:我尝试了PIC32 MX795F512L控制器。7英寸LCD正在显示我运行的程序(我在MPLAB哈蒙中使用了图形对象代码示例)。Y文件夹,但不在PIC32 MZ。
以上来自于百度翻译 以下为原文 hi, last week i bought a 7 inch display to interfacing with pic32mz controller, i am using following components, Pic32mz2048ef144 controller running at 200Mhz, pictail plus epson s1d13517 board, 168 to 132 pin connecter, 7inch custom designed board to interface with pictail board(pins are proper), but, the problem is when the program is loaded it start displaying the Red screen, Green screen, blue screen black white respectively and again the same thing will repeat. i trying to debug from last one i am unable to detect the problem. i checked the data pins and other logical pins like frame, vsync, hsync all signals are coming properly, please help me out to rectify this problem. Note: i tried with the pic32mx795f512l controller the 7inch lcd is displaying the program which i run(i used graphics object code example in mplab hARMony folder), but not in pic32mz. |
9个回答
嗨,你买的各种图形板不是针对PIC32 MZ,而是针对PIC32 MX:HTTP://www. MyCHIP.COM/DeavigoToSs/PositDeLiels.ASPX?PARTNO=AC164127-你真的需要7“?如果你需要开发你自己的板作为AFAIK,没有这样的现有选项。如果你需要800×480分辨率和5“是可以接受的,那么就有一个解决方案:PIC32 MZ EF启动工具包+多媒体扩展板II(DMS307 07)+ 5”WVGA PCAP显示板(AC3200 05)。
以上来自于百度翻译 以下为原文 Hi, The various graphics boards you bought are not meant for PIC32MZ but for PIC32MX : http://www.microchip.com/DevelopmentTools/ProductDetails.aspx?PartNO=AC164127-7 Do you really need 7" ? if so you'll need to develop your own board as AFAIK there is no such existing option. If you need the 800x480 resolution and 5" is acceptable, then there is a solution : PIC32MZ EF starter kit + Multimedia Expansion board II (DM320007)+ 5.0" WVGA PCAP Display Board (AC320005) Regards |
HISRC,感谢您的回复,实际上我需要7英寸LCD显示器的解决方案,目前我有PIC32 MZ控制器。请给我一个解决方案,让我把PIC32 MZ与7英寸显示器,使用(S1D13517显示控制器)。
以上来自于百度翻译 以下为原文 hi RISC, thanks for ur reply, actually i need the solution for 7 inch lcd display, currently i am having pic32mz controller. please give me a solution which allow me to interface pic32mz with 7 inch display, using (s1d13517 display controller). |
显示芯片处于自测试模式。我认为RISC是错误的。它可以工作。用你的适配器板。你选择了合适的项目和配置吗?你使用的是哪种版本的和声。我认为你不能用2.xx的和声来使用它。
以上来自于百度翻译 以下为原文 The display chip is in self test mode. I think RISC is wrong. It can work. With the adapterboard that you have. Did you select a proper project and that configuration. Which version of Harmony are you using. I do not think you can use it with 2.XX Harmony. |
嗨,NKrzman,感谢你的回放,我使用MPLAALAAMONE 1.09。在MPLAB HONE文件夹中没有S1D13517控制器的7英寸显示器的样例代码,所以我所做的是,选择了带有S1D13517控制器和800×480显示分辨率的PIC32 MZ启动器套件。只需选择一个屏幕即可显示。
以上来自于百度翻译 以下为原文 hi NKrzman, thanks for ur replay, i am using mplab haramony version 1.09. there is no sample code in the mplab harmony folder for the 7 inch display with s1d13517 controller, so what i did is, i select the pic32mz starter kit with s1d13517 controller and 800x480 display resolution. and just select a single screen to display. |
所以你从头开始建了一个新项目?我会复制一个现有的,然后修改它为您的显示。我稍后再看。您可能不得不做一些额外的修改,因为该芯片的驱动程序有一些问题,并且总线时序不太正确。也不是更好的芯片可用的大小显示。
以上来自于百度翻译 以下为原文 So you built a new project from scratch? I would make a copy of an existing one then modify it for your display. I will see what is there later. You may have to make some additional modifications since the driver for that chip has some issues and the bus timing is not quite right. Also not the are better chips available fo that size display. |
嗨,NKrzman,我试图建立一个新的项目使用MPLA-和谐1.09通过选择PIC32 MZ EF启动器套件,通过手动选择S1D1驱动程序,也使用自定义显示选项来选择800 X480显示模块。但我没有得到结果。
以上来自于百度翻译 以下为原文 hi NKrzman, I tried to build a new project using MPLAB harmony 1.09 by selecting pic32mz ef starter kit, by manually selecting the s1d1 driver and also use the custom display option to select the 800x480 display module. but i am not getting result. |
在StasyInIt.CdvvpPMP00IrimalIZE()中查找这些行;/ /在此处添加此行DRVYPMP00TimeGET(PMPXDATAWAWITITYONE,PMPYSTROBYWAITIT16,PMPYDATAL HOLDDY3);总线太快,这将使它慢下来,它不是100%正确的,但似乎工作的和谐和睦假设假定为26.66666。MHz的MX总线,MZ默认为100MHz的和谐。你可以把巴士减速到266 66 66赫兹。
以上来自于百度翻译 以下为原文 Find these lines in system_init.c DRV_PMP0_Initialize(); DRV_PMP0_ModeConfig(); // Add this Line here DRV_PMP0_TimingSet(PMP_DATA_WAIT_ONE, PMP_STROBE_WAIT_16, PMP_DATA_HOLD_3); The Bus is too fast this will slow it down, it is not 100% correct but appears to work well harmony assumes Assumes a 26.66666MHz MX Bus, the MZ defaults to 100Mhz in Harmony. Optinal you can slow the Bus to 26.66666MHz |
嗨,NKrzman,我按照你的建议添加了一行代码(我在代码中粘贴了代码的快照),但是仍然没有运气,我没有在显示器上得到任何改变。
以上来自于百度翻译 以下为原文 hi NKrzman, i added the above line of code as you suggests(snapshot of where i pasted the code is in image), but still no luck, i didn't get any changes in the display. Attached Image(s) |
嗨,NKurzman,现在开始工作了。问题在于液晶显示器。我从NeWaveN买了LCD,在LCD引脚中,其中一个引脚没有连接,但不幸的是,我把它弄得很高,一旦我把连接从高电平移除到没有连接,它就开始工作。感谢您宝贵的时间来指导我。
以上来自于百度翻译 以下为原文 hi NKurzman, it's working now. the problem is in LCD display. i bought LCD from newheaven, among LCD pins one of the pin is NOT CONNECTED but unfortunately i made it high, once i removed the connection from high to No connection, its start working. Thank you for your valuable time for guiding me. |
5306 浏览 9 评论
2070 浏览 8 评论
1973 浏览 10 评论
3243 浏览 3 评论
2279 浏览 5 评论
828浏览 1评论
720浏览 1评论
664浏览 1评论
716浏览 0评论
616浏览 0评论
GMT+8, 2025-1-26 14:18 , Processed in 1.096524 second(s), Total 58, Slave 53 queries .
