我正在设计一个流水线递归加法器树。
该设计适用于2个输入数的功率,但在达到奇数个输入时似乎失败。 结构没问题,但是比特数关闭,这导致运行模拟时的不确定状态。 请看一下。 加布里埃尔 adder_r1.sv 4 KB 以上来自于谷歌翻译 以下为原文 I am designing a pipelined recursive adder tree. The design works for fine for a power of 2 number of inputs but seems to fail when it reaches an odd number of inputs. The structure is okay but the number of bits is off which results in indeterminate state when running a simulation. please take a look. Gabriel adder_r1.sv 4 KB |
假设您使用的是双输入加法器。您需要设计加法器树,以便为输入或中间总和添加转发阶段,这些阶段不会得到好友;-)。
假设您有3个输入,您必须添加前两个,注册输出,并注册3输入,然后可以与第一个加法器的输出配对。您需要设计树,以便所有输入和中间总和得到流水线 通过相同的延迟等于他们的对。 - 如果提供的信息有用,请将答案标记为“接受为解决方案”。给予您认为有用且回复的帖子。 以上来自于谷歌翻译 以下为原文 assuming you are using two-input adders. you need to design your adder tree to add forwarding stages for inputs or intermediate sums which don't get a buddy ;-). Suppose you have 3 inputs, you have to add the first two, register the output, and register the 3 input which can then pair with the output of the first adder. You need to design your tree so that all inputs and intermediate sums get pipelined by the same latency equal to their pair.- Please mark the Answer as "Accept as solution" if information provided is helpful. Give Kudos to a post which you think is helpful and reply oriented. |
2702 浏览 7 评论
3018 浏览 4 评论
2435 浏览 9 评论
3546 浏览 0 评论
2639 浏览 15 评论
3431浏览 1评论
843浏览 1评论
703浏览 1评论
GMT+8, 2025-7-12 20:46 , Processed in 1.643233 second(s), Total 76, Slave 60 queries .
