大家好,
我正在将设计从STM8S105转移到STM8S207。 我正在考虑将时钟速度从最初的16MHz提高到24MHz,以便从核心获得更多的MIPS。 但是,对于时钟而言> 16 MHz,闪存需要1次等待。我想这些指令是由内核从闪存内取出的(即没有缓存)。 如果上述情况属实,则使用24 Mhz时钟核心运行速度会变慢。更快的时钟的唯一好处是更快的外设。 那是对的吗? (嗯,现在我想我应该用范围测试) 谢谢 尼科 以上来自于谷歌翻译 以下为原文 Hi all, I'm moving a design from STM8S105 to STM8S207. I'm thinking of raising the clock speed from originally 16MHz to 24 MHz in order to get more MIPS from the core. However, for clocks > 16 MHz, the flash memory requires 1 waitsate. I suppose that the instructions are fetched by the core from within the flash (i.e. there's no cache). If the above is true, then the core would run slower with the 24 Mhz clock. The only benefit of a faster clock would be faster peripherals. Is that correct? (Hm now I'm thinking that I should test that with a scope) Thanks Nico |
感谢EtaPhi的解释。我确实忽略了32位内存提取。我会在某些时候做一些测量,因为它似乎不容易预测。
干杯 尼科 以上来自于谷歌翻译 以下为原文 Thanks EtaPhi for your explanation. I had indeed overlooked the 32-bit memory fetch. I'll do some measurements at some point because it doesn't seem easily predictable. Cheers Nico |
2927 浏览 1 评论
3293 浏览 1 评论
1879 浏览 1 评论
3731 浏览 6 评论
6144 浏览 21 评论
STM32H7打开DCache后,出现了串口接收信息为空的现象,是哪里出了问题?
33浏览 5评论
用NANO STM32F103RBT6的开发板烧录不了是哪里出了问题?
39浏览 5评论
29浏览 5评论
外部中断触发类型为双边沿触发,进入中断回调后有什么办法判断该边沿是上升沿还是下降沿?
25浏览 5评论
STM32L071CBT6低温环境下无法正常工作是什么原因引起的?
31浏览 5评论
GMT+8, 2025-3-20 07:45 , Processed in 0.628460 second(s), Total 43, Slave 38 queries .
