我在设备中使用STM8L151G6。我已经使用STVP擦除了程序和数据存储器,并在选项字节中设置了引导加载程序检查1和2(虽然我知道这不是必需的,因为地址0x8000处没有数据,bootloader应该立即开始)。
所以我通过UART向设备发送同步字节(0x7F)以启动代码上传,但我没有得到任何响应。参见图片,通道1是设备的RX,通道2是它的TX。 我已经尝试通过拉下RST引脚来重置MCU,这没有用。 可能导致问题的原因是什么? #stm8 #bootloader 以上来自于谷歌翻译 以下为原文 I'm using STM8L151G6 in a device. I've erased program and data memory using STVP and set bootloader checks 1 and 2 in option bytes (although as i understand this is not necessary since there is no data at address 0x8000 bootloader should start right away). So I'm sending synchronisation byte (0x7F) via UART to the device to start code upload, but I'm getting no response. See the pic, channel 1 is device's RX, channel 2 is it's TX. I've tried resetting the MCU by pulling down the RST pin, that didn't help. What could be causing the problem? #stm8 #bootloader |
弄清楚,与STM无关,PC和电路板之间的电气接触不良。
以上来自于谷歌翻译 以下为原文 Figured it out, had nothing to do with STM, had bad electrical contact between PC and the board. |
2882 浏览 1 评论
3282 浏览 1 评论
1861 浏览 1 评论
3711 浏览 6 评论
6125 浏览 21 评论
对H747I-DISCO写程序时将CN2的st-link复用为usart1,再次烧录时无法检测到stlink怎么解决?
411浏览 2评论
STM32G474RE芯片只是串口发个数据就发烫严重是怎么回事?
510浏览 2评论
STM32处理增量式编码器Z信号如何判断中断是正转的还是反向转的?
334浏览 2评论
使用STM32F407VET6的USB2.0功能,发现ctl后芯片无数据返回,是什么原因可能导致的呢?
246浏览 2评论
用STM32G431开发工程,1.50版本的Package包文件无法输出项目工程
354浏览 2评论
GMT+8, 2025-2-25 00:45 , Processed in 1.056133 second(s), Total 77, Slave 61 queries .
