有关FS_SPD的数据表中似乎有错误。对于初学者来说,最大值是h3FF而不是所述的hFF。但是,如果我在128微步模式下运行并且超过FS_SPD阈值,它实际上并没有切换到全步模式,它看起来更像是中间微步模式。我在示波器上确认了这一点,它与在全步模式下运行电机不同。顺便说一下,我已经设法以高达3400RPM的速度运行NEMA34。
#l6470#l6470 以上来自于谷歌翻译 以下为原文 There seems to be an error in the datasheet concerning FS_SPD. For starters the maximum value is h3FF and not hFF as stated. But if I am running in 128 microstep mode and the FS_SPD threshold is crossed it does not actually switch to full-step mode, it looks more like an in-between microstep mode. I have confirmed this on the scope, it's not the same as running the motor in full-step mode. BTW, I have managed to run the NEMA34 at up to 3400RPM. #l6470 #l6470 |
你好,
你在微步模式之间的''''是什么意思? 当电压模式驱动全步运行时,电机相位由电压驱动 方波,但BEMF仍然是正弦波。产生的电流不是通过电流模式控制获得的当前方波,而是非常类似于当前模式达到其驱动限制时所获得的波形(类似于线圈的充电和放电)。 电压模式驱动的主要优点是平滑度,因此在使用全步时不会产生最佳效果。全步/电压模式对应仅在特定情况下使用。 如果您愿意,可以发布波形,以便我们检查是否存在其他问题。 亲切的问候 恩里科 以上来自于谷歌翻译 以下为原文 Hello, the what do you exactly mean with ''''in-between microstep mode''? When the voltage mode driving operates in full-step, the motor phases are driven with a voltage square wave, but the BEMF is still sinusoidal. The resulting current is not the current square wave obtained by current mode control, but is very similar to the waveform you obtain when the current mode reaches its driving limit (something like the charge and discharge of a coil). Voltage mode driving main advantage is the smoothness, so it does not give the best results when full-step is used. The full-step/voltage mode pair should be used in particular scenarios only. If you want you can post your waveforms, so we can check if some other issue is present. Kind Regards Enrico |
2801 浏览 1 评论
3258 浏览 1 评论
1832 浏览 1 评论
3684 浏览 6 评论
6081 浏览 21 评论
对H747I-DISCO写程序时将CN2的st-link复用为usart1,再次烧录时无法检测到stlink怎么解决?
384浏览 2评论
STM32G474RE芯片只是串口发个数据就发烫严重是怎么回事?
475浏览 2评论
STM32处理增量式编码器Z信号如何判断中断是正转的还是反向转的?
303浏览 2评论
使用STM32F407VET6的USB2.0功能,发现ctl后芯片无数据返回,是什么原因可能导致的呢?
223浏览 2评论
用STM32G431开发工程,1.50版本的Package包文件无法输出项目工程
328浏览 2评论
GMT+8, 2025-1-24 20:17 , Processed in 1.360394 second(s), Total 77, Slave 61 queries .
