嗨,所有,我使用PIC32 MM000 64 GPL028设备与2.6V电源。尝试写双字写后,我读通过皮卡3 0X…4800 - DFFFFFFF FFFFF 6dB值。值更改但不正确。我尝试用代码从600 01121G.PDF AppNoT和在调试器中检查调试器的正确值,值正确,但结果是错误的。现在我不明白怎么回事。一切看起来都像是在工作。明天我将尝试使用Pig32 mm PIB模块使用Explorer 16/32板进行测试。
以上来自于百度翻译 以下为原文 Hi All, I used PIC32MM0064GPL028 device with 2.6V power. Try wrote double word uint32_t data_h, data_l, lc_addr; lc_addr = 0x1D004800; __builtin_disable_interrupts(); data_h = 0x00000000; data_l = 0x11111111; NVMDATA0 = data_l; NVMDATA1 = data_h; NVMADDR = lc_addr; NVMCON = 0; NVMCONbits.NVMOP = 2; NVMCONbits.WREN = 1; NVMKEY = 0x0; NVMKEY = 0xAA996655; NVMKEY = 0x556699AA; NVMCONbits.WR = 1; while (NVMCONbits.WR); NVMCONbits.WREN = 0; res = NVMCON; if (res & 0x3000) { ret = 1; } __builtin_enable_interrupts(); After writing I read via PicKit 3 0x...4800 - DFFFFFFF FFFFF6DB values. Values changed but incorrect. I try a lot of test with code from 60001121g.pdf AppNote and check by debugger correct values in regs, values writed correct but result is wrong. Now I don't understand what's wrong. All looking as working. Tomorrow I'll try do some tests with Explorer 16/32 board with PIC32MM PIB module. |
6个回答
你从哪里得到的0x1f00 XXXX地址?根据数据表,该地址范围被保留,即没有任何内容。图4.3页36。有效闪存地址范围为0x1dMAMO-0x1d00 FFFF。
以上来自于百度翻译 以下为原文 Where did you get the 0x1F00xxxx address from? According to the datasheet, that address range is RESERVED, i.e. there is nothing there. Figure 4.3 page 36. The valid flash address range is 0x1D000000 - 0x1D00FFFF |
你说得对,我写的地址是0x1D0800,我输入邮件时出错。
以上来自于百度翻译 以下为原文 You are right, my address for writing is 0x1D004800 my mistake when typing a post message. |
我已经发现调试器在代码空间被正确写入之后显示值的问题。我建议把代码空间的写入值读入RAM内存并检查RAM。
以上来自于百度翻译 以下为原文 I have seen problems with debugger showing values in code space correctly after it has been written to. I suggest reading written values of code space back into ram memory and inspecting the ram. |
不,我通过IPE Microchip的工具读取程序内存,而不是过调试器。在调试器中,我只是寄存器的控制值。
以上来自于百度翻译 以下为原文 No. I was read Programm Memory via IPE Microchip's tool not over debugger. Over debugger I was control values of registers only. |
上次更新。我使用PixPIC32 MM000 64 GPL36的探险家16/32。对该芯片的微芯片进行了简单的修改。所有的工作都很好:擦除&写双字&读双字。我用同样的函数来做它。它的工作。现在我的意思是低功耗电压(+2.6V)的更新FW的问题。有人用低功率电压改变FW吗?明天我会做更多的测试。
以上来自于百度翻译 以下为原文 Last update. I used Explorer16/32 with PIM PIC32MM0064GPL36. Simple example from Microchip for this board was modified. All works well: Erase->Write double word->Read double word. I was used same as functions for do it. And it's working. Now I mean that is problem with low power voltage (+2.6V) for update FW. Anyone use change FW with low power voltage? I'll do more tests tomorrow. |
我发现有什么不对。串行USB -TTL+3.3V转换器连接到MCU +2.6V的主要问题。
以上来自于百度翻译 以下为原文 I found what's wrong. Serial USB-TTL +3.3V converter connected to MCU with +2.6V main problem. |
5064 浏览 9 评论
1945 浏览 8 评论
1879 浏览 10 评论
3106 浏览 3 评论
2177 浏览 5 评论
618浏览 1评论
495浏览 1评论
351浏览 1评论
520浏览 0评论
427浏览 0评论
GMT+8, 2024-9-22 03:53 , Processed in 1.278696 second(s), Total 86, Slave 70 queries .
