我有一些问题,试图找出如何打开和测试一个和谐的样本应用程序,工作在PIC32 MX2048 ECH144初学者工具包。我希望能够在一个CDC模式下使用起动器工具包作为USB设备。我安装的工具是:MPLAB-X VER 3.55 XC32 VER 1.40和声FER 2.02BCAN,有人帮助我理解如何从微芯片上获得一个预先制作的应用程序来运行起动器套件。作为后续问题,可以让应用程序以支持OTG行为的方式运行,其中初学者工具包可以切换到主机模式,以将其USB头发送出去。
以上来自于百度翻译 以下为原文 I am having some problems trying to figure out just how to open and test a HARMony sample app that works on the PIC32MX2048ECH144 Starter Kit. I want to be able to work with the starter kit operating as a USB Device in a CDC mode. The tools I have installed are: MPLAB-X Ver 3.55 XC32 Ver 1.40 Harmony Ver 2.02b Can someone help me understand how to get a pre-made app from Microchip to run on the starter kit? As a follow up question to that is it possible to then get the app to run in a way that it supports OTG behavior where the Starter Kit can switch to host mode to source power out its USB header. |
找到一个项目。然后,你需要从电路板列表中选择你的板。和声V2.xx仍然支持PIC32 MX2048 ECH144芯片吗?该芯片被替换为PIC32 MX2048 EFH144。ECH芯片有大量的勘误表并被废弃。仍然可用,但不推荐用于新的设计。我不认为有任何USB OTG的例子。
以上来自于百度翻译 以下为原文 Find a project. Then ,You need to select your board from the list of boards. Does Harmony V2.XX still support the PIC32MX2048ECH144 chip? that chip is replaced with the PIC32MX2048EFH144. The ECH chips had a lot of errata and are abandoned. Still available, but not recommended for new designs. I do not think there are any USB OTG examples. |
5064 浏览 9 评论
1945 浏览 8 评论
1879 浏览 10 评论
3104 浏览 3 评论
2175 浏览 5 评论
616浏览 1评论
487浏览 1评论
345浏览 1评论
516浏览 0评论
423浏览 0评论
GMT+8, 2024-9-21 04:38 , Processed in 0.832657 second(s), Total 43, Slave 38 queries .
