你好。
我可以使用一台强大的PC作为远程构建服务器吗? 为了构建项目(xst,par,map等),设计人员可以连接到它,加载HDL文件和构建项目。 我怎样才能做到这一点? 谢谢。 以上来自于谷歌翻译 以下为原文 Hello. Can I use one powerfull pc as remote build server? In order to build projects (xst, par, map, etc.), designers can connect to it, load HDL files and build projects. How can I do that? Thanks. |
7个回答
嗨,你的意思是powerpull远程构建服务器?如果你的意思是一台高配置的机器,只要你使用支持的操作系统并且安装了这些工具就没问题。你是否希望将项目放在远程服务器上或仅使用
服务器编程和调试?问候,Achutha -------------------------------------------------- -------------------------------------------请注意 - 请标记答案 如果提供的信息有用,请“接受为解决方案”。给予您认为有用并回复导向的帖子。感谢Kudos .------------------------ -------------------------------------------------- -------------- 以上来自于谷歌翻译 以下为原文 Hi , What do you mean by powerpull remote build server? If you mean a high configuration machine, that's fine as long as you use the supported operating systems and the tools are installed. Are you looking to have the project in remote server or only use the server to program and debug? Regards, Achutha --------------------------------------------------------------------------------------------- Kindly note- Please mark the Answer as "Accept as solution" if information provided is helpful. Give Kudos to a post which you think is helpful and reply oriented. ---------------------------------------------------------------------------------------- |
嗨,
您可以安装和运行与桌面类似的可执行文件。 请参阅以下文档的第11页.http://www.xilinx.com/support/documentation/sw_manuals/xilinx14_2/iil.pdf 这涵盖了不同的操作系统。 --Hem -------------------------------------------------- --------------------------------------------请注意 - 请注明 如果提供的信息有用,请回答“接受为解决方案”。给予您认为有用并回复导向的帖子。感谢K-- -------------------------------------------------- --------------------- 以上来自于谷歌翻译 以下为原文 Hi, You can install and run the executables similar to your desktop. Refer to page 11 of the following document. http://www.xilinx.com/support/documentation/sw_manuals/xilinx14_2/iil.pdf This covers for different OS. --Hem ---------------------------------------------------------------------------------------------- Kindly note- Please mark the Answer as "Accept as solution" if information provided is helpful. Give Kudos to a post which you think is helpful and reply oriented. ---------------------------------------------------------------------------------------------- |
我想让项目在远程服务器上。
我想在服务器上构建它(xst,map,par和其他)。 我可以使用远程桌面协议连接到服务器,但是一些开发人员可以同时使用它。 因此,这种变体变得无关紧要.Xilinx有一些远程构建/编译机制吗? 以上来自于谷歌翻译 以下为原文 I want to have the project in remote server. I want to build it (xst, map, par and others) on server. I could use Remote Desktop Protocol to connect to the server, but several developers can use it simultaneously. So, this variant becomes not relevant. Do Xilinx have some mechanisms for remote building/compiling? |
从根本上说。
我的经验。 我们最终使用远程桌面到一些机架式机器。 但是: 我们停止使用它,当'好'桌面和'伟大'服务器之间的差异变得如此之小。 Vivado特别似乎只是狼吞虎咽, 所以我们所有的机器人现在都有SSD和快速大公羊,以及一个很好的视频卡, 一台好的台式机可以花费500英镑,一台优质的服务器售价3000英镑,速度差异很小,成本和麻烦都要多得多。 以上来自于谷歌翻译 以下为原文 Been down this root. My experiance. We ended up using remote desk top to some rack machines. BUT : We stoped using this though, when the difference between a 'good' desk top and a 'great' server has become so small. Vivado especialy seems to just gobble ram, so all our machiens now have SSD and fast big rams, and a good video card, A good desk top machine can cost GBP 500, a great server costs GBP 3000, the difference in speed was minimal, for a lot more cost and hassle. |
andrew_ced写道:
一台好的台式机可以花费500英镑,一台优质的服务器售价3000英镑,速度差异很小,成本和麻烦都要多得多。 价格差异源于不同的服务要求。 服务器必须全天候运行并处理各种同时的网络和磁盘服务器请求。 做FPGA构建的工作站只需要足够的RAM来处理设计和快速处理器。 磁盘和网络访问非常无趣 ----------------------------是的,我这样做是为了谋生。 以上来自于谷歌翻译 以下为原文 andrew_ced wrote:The price difference results from the different service requirements. The server has to be up 24/7 and handle all sorts of simultaneous network and disk server requests. A workstation doing FPGA builds just needs enough RAM to handle the design and a fast processor. Disk and network access are pretty uninteresting ----------------------------Yes, I do this for a living. |
xilinxuser3写道:
我可以使用一台功能强大的PC作为远程构建服务器吗? 为了构建项目(xst,par,map等),......我该怎么做?... Xilinx是否有一些远程构建/编译机制? 我认为实际问题仍然没有答案。 显然,可以使用远程桌面,并且可以将服务器用于普通的个人计算机来运行软件。 如果使用Linux,我会看到分布式SmartXplorer选项,但我还没有找到任何关于调用的信息,例如远程机器上的xst。 我认为这可以做到,但我找不到有关如何做的信息。 我个人希望这主要用于SmartXplorer,但我没有运行Linux,所以我运气不好。 玩笑 以上来自于谷歌翻译 以下为原文 xilinxuser3 wrote: Can I use one powerfull pc as remote build server? In order to build projects (xst, par, map, etc.), ... How can I do that?I believe the actual question(s) still remains unanswered. Clearly remote desktop can be used and a server can be used a a normal personal computer to run software. I see distributed SmartXplorer options if one is using Linux, but I have not found anything about calling, for instance, xst on a remote machine. I think this can be done, but I am not finding the information on how to do it. I personaly want this mostly for SmartXplorer, but I am not running Linux so I am out of luck. Josh |
我同意安德鲁。
我宁愿在使用四核i7,快速SSD驱动器和32GB内存的本地台式机上运行Vivado,而不是使用远程计算服务器。 远程计算服务器的问题在于您无法控制它正在执行的操作。 在等待Vivado完成时,另一个用户可能会开始做大工作。 此外,Vivado还将大量数据写入磁盘。 如果您的文件在网络附加存储上,则运行时间可能会增加十倍。 以上来自于谷歌翻译 以下为原文 I concur with Andrew. I would much rather run Vivado on a local desktop machine with quad-core i7, fast SSD drive and 32GB memory than use a remote compute server. The problem with a remote compute server is that you don't control what it is doing. Another user may start a big job while you are waiting for Vivado to finish. Also, Vivado writes a lot of data to disk. If your files are on network attached storage run time can go up by a factor of ten. |
2609 浏览 7 评论
2933 浏览 4 评论
2379 浏览 9 评论
3483 浏览 0 评论
2561 浏览 15 评论
3144浏览 1评论
734浏览 1评论
612浏览 1评论
GMT+8, 2025-4-27 20:27 , Processed in 1.460670 second(s), Total 87, Slave 71 queries .
