@alexmiculescuminor评论:非阻塞作业用'
嗨!
我不明白非阻塞分配是如何按顺序或并行执行的? 永远@(posedge clk) 开始 x = 2; y = x; 结束 VS 永远@(posedge clk) 叉子 x = 2; y = x; 加入 VS 赋值x = 2; 赋值y = x; 我不了解硬件级别的情况。 在什么情况下可能会出现种族情况? 如果所有这些按顺序执行有什么好处? 谢谢! 以上来自于谷歌翻译 以下为原文 Hi! I don't understand how non blocking assignments are executed in sequence or in parallel? always @(posedge clk)beginx = 2;y = x;endvsalways @(posedge clk)forkx = 2;y = x;join vs assign x = 2; assign y = x; I don't grasp what is happening at the hardware level. In what cases race condition might occur? If all those are executed in sequence what are the advantages? Thank you! |
@alexmiculescuminor评论:非阻塞作业用' |
在硬件中它是全部并行的。
但是,综合工具能够使并行硬件像顺序执行一样 - 因此阻塞分配“看起来”是顺序的,即使它们不是。不应该出现条件。 据我所知,不可能导致实际上可以合成的竞争条件; 竞争条件往往会导致合成期间出现多个驱动程序错误。 您可以在硬件中获得竞争条件(例如,在相关时钟边沿之前没有完全到达触发器的信号)但如果设计被正确约束并且它通过时序则不会发生这种情况。 简而言之,如果你看到竞争条件,工具可能会抛出错误或警告。 以上来自于谷歌翻译 以下为原文 In hardware it's all parallel. However, the synthesis tool is able to make the parallel hardware act like it's doing sequential execution - so blocking assignments "look" sequential even though they aren't. Race conditions should not occur. As far as I know, it's not possible to cause a race condition that can actually be synthesized; race conditions tend to result in multiple-driver errors during synthesis. You can get race conditions in hardware (eg. a signal that doesn't quite reach the flip-flop before the relevant clock edge) but those shouldn't occur if the design is correctly constrained and it passes timing. In short, if you're seeing race conditions, the tools will probably be throwing either errors or warnings. |
2604 浏览 7 评论
2923 浏览 4 评论
2376 浏览 9 评论
3479 浏览 0 评论
2554 浏览 15 评论
3126浏览 1评论
727浏览 1评论
603浏览 1评论
GMT+8, 2025-4-23 08:31 , Processed in 1.464444 second(s), Total 79, Slave 63 queries .
