嗨社区,
我希望有人可以就Spartan 6 FPGA的EEPROM(XCF32P)提出一些建议。 我们的卡与FPGA& 必须保证EEPROM工作在100degC。 对于FPGA,我们已经将使用工业级版本,因此我们在那里很好。 但是,工业级EEPROM(XCF32P)仅建议在高达85摄氏度时使用。 我们是否应该为EEPROM添加散热片以确保它不会在100degC时失效? 或者不添加任何散热器,因为根据数据表,结温的绝对最大额定值为125deg? 有人可以确认一下吗? 谢谢。 最好 - 王牌 以上来自于谷歌翻译 以下为原文 Hi Community, I hope somebody can give some advice with regards to EEPROM (XCF32P) for Spartan 6 FPGAs. Our card with the FPGA & EEPROM must be guaranteed to work at 100degC. For the FPGA, we are already going to use an industrial grade version so we are good there. However the industrial grade EEPROM (XCF32P) is only recommended to be used up to 85degC. Should we add heatsinks for the EEPROM in order to guarantee that it will not fail at 100degC? or not add any heatsinks since according to the datasheet the absolute max rating for the junction temp is given to be 125degC? Can somebody please confirm? Thank you. Best -- ace |
6个回答
散热片只有在(a)环境温度低于85摄氏度且(b)芯片本身由于其产生的热量而高于85摄氏度时才有用。
在这种情况下,散热器将使芯片温度更接近环境温度,并且足够大的散热器(和/或风扇)将使其保持在85°C以下。如果环境温度高于85°C,则没有散热器/风扇将使芯片温度低于85°C - 这样做会违反热力学定律。 有效的热泵(例如TEC)会,但这将需要更多的功率和更多的冷却。绝对最大额定值定义了损坏发生之前的限制。 低于85degC,该设备将工作。 在85°C和125°C之间,设备无法工作,但不会损坏。 高于125摄氏度,设备可能会永久性损坏。我建议更换为不同的闪存芯片。 Spartan 6支持Atmel(现在的Adesto)DataFlash芯片,提供105degC和125degC两种版本。 在原帖中查看解决方案 以上来自于谷歌翻译 以下为原文 Heatsinks will only help if (a) ambient temperature is below 85degC and (b) the chip itself goes above 85degC due to the heat it generates. In this case a heatsink will bring the chip temperature closer to ambient, and a sufficiently large heatsink (and/or fan) will keep it below 85degC. If ambient is above 85degC, then no heatsink/fan is going to get the chip below 85degC - doing so would violate the laws of thermodynamics. An active heat pump (eg. a TEC) would, but that would demand more power and even more cooling. The absolute maximum rating defines the limit before damage will occur. Below 85degC the device will work. Between 85degC and 125degC the device won't work, but it won't be damaged. Above 125degC the device may be permanently damaged. I suggest changing to a different flash chip. The Atmel (now Adesto) DataFlash chips are supported on the Spartan 6, and available in both 105degC and 125degC variants. View solution in original post |
在这种情况下,散热器将使芯片温度更接近环境温度,并且足够大的散热器(和/或风扇)将使其保持在85°C以下。如果环境温度高于85°C,则没有散热器/风扇将使芯片温度低于85°C - 这样做会违反热力学定律。 有效的热泵(例如TEC)会,但这将需要更多的功率和更多的冷却。绝对最大额定值定义了损坏发生之前的限制。 低于85degC,该设备将工作。 在85°C和125°C之间,设备无法工作,但不会损坏。 高于125摄氏度,设备可能会永久性损坏。我建议更换为不同的闪存芯片。 Spartan 6支持Atmel(现在的Adesto)DataFlash芯片,提供105degC和125degC两种版本。 以上来自于谷歌翻译 以下为原文 Heatsinks will only help if (a) ambient temperature is below 85degC and (b) the chip itself goes above 85degC due to the heat it generates. In this case a heatsink will bring the chip temperature closer to ambient, and a sufficiently large heatsink (and/or fan) will keep it below 85degC. If ambient is above 85degC, then no heatsink/fan is going to get the chip below 85degC - doing so would violate the laws of thermodynamics. An active heat pump (eg. a TEC) would, but that would demand more power and even more cooling. The absolute maximum rating defines the limit before damage will occur. Below 85degC the device will work. Between 85degC and 125degC the device won't work, but it won't be damaged. Above 125degC the device may be permanently damaged. I suggest changing to a different flash chip. The Atmel (now Adesto) DataFlash chips are supported on the Spartan 6, and available in both 105degC and 125degC variants. |
高手,
100C环境(气温)? 这超出了规范,因为工业设备是100 C结温,而不是环境(环境)。 Austin Lesea主要工程师Xilinx San Jose 以上来自于谷歌翻译 以下为原文 ace, 100C environment (air temperature)? That is out of specification as out industrial device is 100 C junction temperature, not environment (ambient). Austin Lesea Principal Engineer Xilinx San Jose |
嗨u4223374,
谢谢你的回复。 我们会根据您的建议找到不同的EEPROM。 最好的祝福, - 王牌 以上来自于谷歌翻译 以下为原文 Hi u4223374, Thank you for the helpful reply. We will find a different EEPROM as you suggested. Best Regards, -- ace |
嗨奥斯汀,是100C意味着气温。
感谢您的确认。在这种情况下,我们会为这种环境找到更适合的设备。最好的问候, - 王牌 以上来自于谷歌翻译 以下为原文 Hi Austin, Yes 100C means air temperature. Thank you for the confirmation. We will find a better suited device for this environment in this case. Best Regards,-- ace |
高手,
FPGA的工业温度范围也不起作用。 您将需要军用级设备(125 C交界处)。 Austin Lesea主要工程师Xilinx San Jose 以上来自于谷歌翻译 以下为原文 Ace, The industrial temp range for the FPGA won't work either. You will require the military grade device (125 C junction). Austin Lesea Principal Engineer Xilinx San Jose |
2512 浏览 7 评论
2881 浏览 4 评论
2338 浏览 9 评论
3431 浏览 0 评论
2519 浏览 15 评论
2631浏览 1评论
671浏览 1评论
536浏览 1评论
822浏览 0评论
GMT+8, 2025-3-7 09:22 , Processed in 1.504130 second(s), Total 87, Slave 71 queries .
