大家好
我在设置LIS3DH模块以检测移动时遇到问题。 更确切地说,我希望设备在经历32毫秒加速度变化0.5秒时将INT1引脚设置为向下。 这是我的设置: CTRL_REG1 = 0x20 // 10Hz,正常功耗模式,ZXY使能 CTRL_REG2 = 0x00 //没有HP过滤器 CTRL_REG3 = 0x40 // IA1启用 CTRL_REG4 = 0x10 //缩放4g CTRL_REG5 = 0x08 //中断1引脚锁存 INT1_THS = 0x01 // 32mg阈值 INT1_DURAtiON = 0x05 // 0.5s激活中断 INT1_CFG = 0x7F //启用6D方向模式,启用所有方向 现在,当我读取INT1_SRC寄存器时,它总是显示0x00,INT1引脚永远不会发生故障...... 有趣的是,当我设置 INT1_THS至少为0x0A它可以工作,但对我来说太过分了! soemone可以帮我解决这个案子吗? 以上来自于谷歌翻译 以下为原文 Hello all I have a problem with setting LIS3DH module to detect movement. To be more precise, I want the device to set the INT1 pin down when the it experiences 32mg acceleration change for 0.5 second. Here are my settings: CTRL_REG1 = 0x20 //10Hz, normal power mode, ZXY enable CTRL_REG2 = 0x00 //no HP filters CTRL_REG3 = 0x40 //IA1 enable CTRL_REG4 = 0x10 //scale 4g CTRL_REG5 = 0x08 //interrupt 1 pin latched INT1_THS = 0x01 //32mg threshold INT1_DURATION = 0x05 // 0.5s to activate interrupt INT1_CFG = 0x7F //6D direction mode enabled, all directions enabled Now, when I read INT1_SRC register it always shows 0x00 and INT1 pin never goes down... Funny thing is that when I set INT1_THS to at least 0x0A it works but it is too much for me! Could soemone help me with this case? |
嗨,Miroslav,我的要求是检测IIS2DH传感器门打开/关闭的运动,我已经尝试过以上配置,但是当我被中断并读取x,y和z轴值并且它为零时。那么,这有什么问题,请你帮我检测一下开门/关门。谢谢你的时间。
以上来自于谷歌翻译 以下为原文 Hi, Miroslav, My requirement is to detect movement of the door open/close for IIS2DH sensor and I have tried with above configuration but when I have getting interrupted and read x,y and z axis values and it is zero. So, what is wrong with this and could you please help me to detect door open/close. Thanks for your time. |
2777 浏览 1 评论
3251 浏览 1 评论
1824 浏览 1 评论
3667 浏览 6 评论
6061 浏览 21 评论
1347浏览 4评论
对H747I-DISCO写程序时将CN2的st-link复用为usart1,再次烧录时无法检测到stlink怎么解决?
372浏览 2评论
STM32G474RE芯片只是串口发个数据就发烫严重是怎么回事?
465浏览 2评论
STM32处理增量式编码器Z信号如何判断中断是正转的还是反向转的?
292浏览 2评论
使用STM32F407VET6的USB2.0功能,发现ctl后芯片无数据返回,是什么原因可能导致的呢?
211浏览 2评论
GMT+8, 2025-1-9 20:30 , Processed in 1.023406 second(s), Total 43, Slave 38 queries .
