在PoPPSoC型CY8CRED04G01上,外部时钟可以连接到P1(4)。
在大多数PSoC1器件上,可以连接外部晶体+电容器,但需要2个引脚。 是否可以直接将外部晶体(24 MHz或任何)连接到该管脚上?如何? 或者我需要做一个分离的水晶+驱动电路来驱动它吗? 提前感谢 伦斯 以上来自于百度翻译 以下为原文 On PowerPSOC like CY8CLED04G01 an external clock can be connected to P1(4). On most PSOC1 devices an external crystal + capacitors can be connected, but that needs 2 pins. Is it possible to connect a external crystal (24 Mhz or whatever) directly to that pin? and how? or do I need to make a seperate crystal + driver circuit to drive it? Thanks in advance Rens |
3个回答
在CY8CURD04G01芯片内没有XTAL驱动程序,因此您必须为自己提供具有适当电压电平的时钟源。不使用内部振荡器的原因是什么?你在运行RTC吗?只要你依赖IMO,即使在UARTs ets的情况下,稳定(在供应和温度之内)也是可以的。
快乐时钟 鲍勃 以上来自于百度翻译 以下为原文 There is no xtal-driver within the CY8CLED04G01-chip, so you have to provide your own clock source with appropiate voltage-level. What is the reason not to use the internal oscillators? Are you running a RTC? As long as you depend on the IMO the stability (within supply and temperature) would be alright even for UARTs ets. Happy clocking Bob |
谢谢鲍伯,
主要原因是UART。 我找到了一个描述IMO(AN5997)的温度计算的AN。 这也保证了IMO的稳定性对于UART来说是足够的。 另一个原因是RTC是设计中的一个选项。 所以我会再想一想,如果需要的话,提供一个分离的晶体振荡器。 当做 伦斯 以上来自于百度翻译 以下为原文 Thanks Bob, The main reason was UART. I found a AN that describes temperature compenation for IMO (AN 55973). That also assured me that IMO stability is sufficient for UART. Another reason is RTC as an option in the design. So I'll think it over again and, if needed, provide a seperate crystal oscilator. Regards Rens |
很晚,我又来了这篇文章,我有一个想法:
当你需要一个RTC的选项,你的PSoC正在驱动LED(环境光)?)将有一个主控制LED PSoC。这可以用来同步主机的RT时钟(带有X-TAL)到从机,这样节省了一些硬件。唯一值得注意的是:不要使用内部低功率振荡器(ILO),因为它的规格更差,对于RTC绝对是不可用的。 鲍勃 以上来自于百度翻译 以下为原文 Rather late I came over this post again and I've got an idea: When you need the option for an RTC and your PSoCs is driving LEDs (Ambient light??) there will be a master controlling the LED-PSoC. This can be used to synchronize the master's RTClock (with x-tal) to the slave, saving this way some hardware. The only point to watch-out for is: Not to use the internal low-power oscillator (ILO) because its specs are rather worse and absolutely unusable for an RTC. Bob |
760个成员聚集在这个小组
加入小组2160 浏览 1 评论
1909 浏览 1 评论
3732 浏览 1 评论
1841 浏览 6 评论
1589 浏览 1 评论
797浏览 2评论
555浏览 2评论
493浏览 2评论
452浏览 2评论
1309浏览 2评论
GMT+8, 2025-3-10 18:53 , Processed in 1.062247 second(s), Total 78, Slave 62 queries .
