扫一扫,分享给好友
嗨,大家好,
当我合成我的项目时,检测到错误[Synth 8-316]非法模块递归。 这意味着什么以及如何解决问题? 我在互联网上搜索,但我找不到答案。 谢谢! 以上来自于谷歌翻译 以下为原文 Hi everyone, when I synthesize my project, there is an error [Synth 8-316] illegal module recursion detected. What does this mean and how to solve the problem? I search on internet, but I cannot find the answer. Thank you! |
3个回答
如果您发布代码,帮助您会容易得多...
但是,从消息中看来,模块似乎试图实例化自身的实例(这就是递归意味着什么) - 直接或通过其他实例。 虽然递归是软件算法编码中非常强大的工具,但在RTL编码中它是没有意义/不可能/非法的。 Avrum 在原帖中查看解决方案 以上来自于谷歌翻译 以下为原文 It would be much easier to help you if you posted the code... But, from the message, it seems that a module is trying to instantiate an instance of itself (that's what recursion means) - either directly, or through other instances. While recursion is a very powerful tool in the coding of software algorithms, it is meaningless/impossible/illegal in RTL coding. Avrum View solution in original post |
如果您发布代码,帮助您会容易得多...
但是,从消息中看来,模块似乎试图实例化自身的实例(这就是递归意味着什么) - 直接或通过其他实例。 虽然递归是软件算法编码中非常强大的工具,但在RTL编码中它是没有意义/不可能/非法的。 Avrum 以上来自于谷歌翻译 以下为原文 It would be much easier to help you if you posted the code... But, from the message, it seems that a module is trying to instantiate an instance of itself (that's what recursion means) - either directly, or through other instances. While recursion is a very powerful tool in the coding of software algorithms, it is meaningless/impossible/illegal in RTL coding. Avrum |
Avrum,
实际上,递归在RTL设计中与在软件中一样有用并且工作正常(在Simulation和Vivado综合中)。 适用相同的规则 - 您必须在最低级别具有某种适当的终止条件。 我猜猜pligroup的终止条件有问题。 我们在所有版本的Vivado中都使用了递归。 我想我们甚至在ISE中使用过它。 工作正常。 *编辑*我正在谈论OP的消息所指示的模块递归。 我们还在函数调用中使用了递归。 这也有效。 问候, 标记 以上来自于谷歌翻译 以下为原文 Avrum, Actually recursion is just as useful in RTL design as in software and works fine (both in Simulation, and Vivado synthesis). Same rules apply - you must have some kind of appropriate terminating condition at the lowest level. I'm guessing there's something wrong with pligroup's terminating condition. We've used recursion in all versions of Vivado. I think we even used it in ISE. Works fine. *EDIT* I'm speaking of module recursion as the OP's message indicates. We've also used recursion within function calls. That works too. Regards, Mark |
2567 浏览 7 评论
2904 浏览 4 评论
2359 浏览 9 评论
3453 浏览 0 评论
2540 浏览 15 评论
2969浏览 1评论
699浏览 1评论
572浏览 1评论
862浏览 0评论
GMT+8, 2025-4-4 18:00 , Processed in 1.357997 second(s), Total 47, Slave 41 queries .
