您好,有没有人有关于更换E系列频谱分析仪内部存储器电池的信息和过程?
谢谢 以上来自于谷歌翻译 以下为原文 Hello, Does anyone have information about and the process to replace the internal memory battery on E-Series spectrum analyzers? Thanks |
嗨 - 我们认为“E系列频谱分析仪”指的是ESA-E或ESA-L系列频谱分析仪,包括E4401B,E4402B,E4403B,E4404B,E4405B,E4407B,E4408B和E4411B型号。
如果是这种情况,则附上电池更换程序。 电池部件号为1420-0556。 有可能通过更换电池,某些分析仪开机设置可能出错。 这就是安捷伦建议使用N7800A现场软件执行CPU初始化的原因。 但是,设置的次数是O.K.,但请注意,这不是保证。 因此,在更换电池并将仪器放回原位后,您需要检查以下项目以确保它们正确无误:•输入Z•打开电源•在显示系统中更正型号•耦合•时间•日期 问候 - 以上来自于谷歌翻译 以下为原文 Hi - We think by “E-Series spectrum analyzers”, you are referring to the ESA-E or ESA-L series of spectrum analyzers, which would include models E4401B, E4402B, E4403B, E4404B, E4405B, E4407B, E4408B and E4411B. If that is the case, the battery replacement procedure is attached. The battery part number is 1420-0556. It is possible that by changing the battery that some of the analyzer power on settings may be wrong. This is why Agilent recommends that the CPU Initialization is performed using the N7800A field software. More times than not however, the settings will be O.K., but just be aware that it is not a guarantee. So, after you change the battery and put the instrument back together, you will want to check the following items to be sure they are correct: • Input Z • Power on units • Correct model number in the Show System • Coupling • Time • Date Regards - 附件
1408 浏览 0 评论
2425 浏览 1 评论
2280 浏览 1 评论
2118 浏览 5 评论
3036 浏览 3 评论
1514浏览 1评论
847浏览 0评论
1278浏览 0评论
1408浏览 0评论
GMT+8, 2025-3-10 22:11 , Processed in 1.318853 second(s), Total 76, Slave 60 queries .
