你好,我刚在MPLABX子论坛上发布了这个,但是在这里可能更正确!我的编译器许可证使用MPLABX有点麻烦。我从供应商那里得到了XC32的评估许可证,因为我想尝试一个更高的优化级别来克服我在图形处理中遇到的问题。我认为许可是要持续60天,但现在它已经过期,当我试图升级XC32编译器到V1.43时,我得到了构建错误:我现在只需要使用免费许可(优化到和包括1级),所以有一种完全禁用我是GI补丁的方法吗?文?我猜这是一个Windows注册表条目?我已经完全卸载了XC32编译器的所有版本,然后重新安装了最新版本,但我仍然收到警告。谢谢!
以上来自于百度翻译 以下为原文 Hi there, I just posted this in the MPLABX subforum but it's probably more correct in here! I'm having a little trouble with my compiler license with MPLABX. I was given an evaluation license for XC32 from a supplier as I wanted to try a higher optimisation level to overcome an issue I was having with graphics processing. I think that license was meant to last 60 days, but now it has long expired and when I have tried to upgrade the XC32 compiler to v1.43 I get build errors: Subscription License has not been renewed - the activation server "http://keyverify.microchip.com" gave the unexpected result -1021 I only need to use the free license now (optimisations up to and including level 1) so is there a way of completely disabling the patch I was given? I'm guessing it's a windows registry entry somewhere? I have completely uninstalled all versions of the XC32 compiler and then reinstalled the latest version but I still get the warning. Thanks! |
如果你还没有的话,请发一封电子邮件给Microchip点com。
以上来自于百度翻译 以下为原文 Please send an email to swlicensing at microchip dot com if you haven't already. |
是的,Switter人员为我排序了。我删除了C:CalpDATaMicrochip xCLMSub中的许可证文件,并且不再发出警告。
以上来自于百度翻译 以下为原文 Yes the swlicensing guys sorted it for me. I deleted the license file in C:ProgramDataMicrochipxclmlicense And no more warnings |
5060 浏览 9 评论
1945 浏览 8 评论
1879 浏览 10 评论
3100 浏览 3 评论
2174 浏览 5 评论
615浏览 1评论
484浏览 1评论
343浏览 1评论
515浏览 0评论
422浏览 0评论
GMT+8, 2024-9-20 15:29 , Processed in 1.194285 second(s), Total 78, Slave 62 queries .
