我一直用CCS编程PIC16的旧版本的MPLAB(V891)。现在我需要使用MPLAB X和XC8编译器。所有加载的OK,我可以进入MPLAB。我的问题是:是否有一个文件列出了标准头文件(*.h)以及标准命令及其定义?我有一本参考CCS的大参考书,真的需要MPLab X.那样的东西,我在XC8编译器用户指南中没有看到类似的东西。有什么建议吗?
以上来自于百度翻译 以下为原文 I have been using CCS for programming PIC16's with old version of MPLab (V8.91). I now need to use MPLab X and the XC8 compiler. All loaded OK and I can get into MPLab. My question is: Is there a document which lists the standard Header files (*.h) as well as the standard commands and their definitions? I had a big reference book that came with CCS and really need something like that for MPLab X. I didn't see anything like that in the XC8 Compiler User's Guide. Any suggestions? |
编译器包含一个手册作为PDF。它不包括广泛的图书馆CSS。您可以使用旧的外围库获得一些旧的图片的功能。对于新的图片,你可以使用MCC。
以上来自于百度翻译 以下为原文 The compiler includes a manual as a PDF. It does not include the extensive library CSS does. You can get some of that functionality for older PICs with the legacy peripherial libraries. For newer PICs you can use MCC. |
5424 浏览 9 评论
2124 浏览 8 评论
2038 浏览 10 评论
3293 浏览 3 评论
2335 浏览 5 评论
923浏览 1评论
794浏览 1评论
740浏览 1评论
799浏览 0评论
689浏览 0评论
GMT+8, 2025-4-1 01:57 , Processed in 1.261963 second(s), Total 77, Slave 61 queries .
