扫一扫,分享给好友
我试着用VC++ 6使用CyAPIILB,当我编译时,我得到以下错误:
链接… CyAPI .LIB(CyAPI .Obj:)错误LNK2001:未解析的外部符号 CyAPI .LIB(CyAPI .Obj:):错误LNK2001:未解析的外部符号@ CyAPI .LIB(CyAPI .Obj:):错误LNK2001:未解析的外部符号 CyAPI .LIB(CyAPI .Obj:)错误LNK2001:未解析的外部符号 CyAPI .LIB(CyAPI .Obj:):错误LNK2001:未解析的外部符号 CyAPI .LIB(CyAPI .Obj:)错误LNK2001:未解析的外部符号 CyAPI .LIB(CyAPI .Obj:):错误LNK2001:未解析的外部符号 Debug /CyBulk.EXE:致命错误LNK1120:7未解决的外部问题 是什么引起的?我试图简单地编译与CyAPI.LIB(CyBulk在这种情况下)的例子。 谢谢, 以上来自于百度翻译 以下为原文 I'm trying to use the CyAPI.lib with VC++ 6.0, and when I compile, I get the following errors: Linking... CyAPI.lib(CyAPI.obj) : error LNK2001: unresolved external symbol ___security_cookie CyAPI.lib(CyAPI.obj) : error LNK2001: unresolved external symbol @__security_check_cookie@4 CyAPI.lib(CyAPI.obj) : error LNK2001: unresolved external symbol ___CxxFrameHandler3 CyAPI.lib(CyAPI.obj) : error LNK2001: unresolved external symbol __EH_epilog3 CyAPI.lib(CyAPI.obj) : error LNK2001: unresolved external symbol __EH_prolog3 CyAPI.lib(CyAPI.obj) : error LNK2001: unresolved external symbol __EH_epilog3_GS CyAPI.lib(CyAPI.obj) : error LNK2001: unresolved external symbol __EH_prolog3_GS Debug/cybulk.exe : fatal error LNK1120: 7 unresolved externals What is causing this? I'm trying to simply compile the examples that came with the CyAPI.lib (CyBulk in this case). Thanks, |
作为SUITEUSB的一部分的CyAPI.lib是使用VS2010编译的。我怀疑它将与VC++ 6一起工作。
你看过Athtp://www. CyPress?ID= 4和RID=32529,它必须具有VC++ 6版本的beta版本。 当做, 阿南德 以上来自于百度翻译 以下为原文 The CyAPI.lib that comes as part of SuiteUSB is compiled using VS2010. I doubt it will work with VC++ 6.0. Have you looked at http://www.cypress.com/?id=4&rID=32529 it must have the Beta version of VC++ 6 version. Regards, Anand |
757个成员聚集在这个小组
加入小组2137 浏览 1 评论
1877 浏览 1 评论
3700 浏览 1 评论
1815 浏览 6 评论
1561 浏览 1 评论
756浏览 2评论
512浏览 2评论
471浏览 2评论
422浏览 2评论
1113浏览 2评论
GMT+8, 2025-2-4 07:19 , Processed in 1.003885 second(s), Total 75, Slave 59 queries .
