大家好,
我们如何着手使用新的过滤器组件?我想尝试新的过滤器组件如下: 1)12位数据输入 2)基本汉明窗FIR低通滤波器 12位样本数据概念代码: /全局变量 It16数据[128 ]={…};/ /我将从另一个程序导入的一些输入值数组 It16输出(256);/ /空数组,它将保持滤波器的输出(大到足以解释由于卷积而增大的大小) 主回路UIT16 I;/计数器 空主程序() { 筛选器启动(); (i=0;i,lt;128;i++) { FieldWrute16(数据); CyDelay(1); 输出=FieldRead 16(); } //完成后将数据打印到测试终端 } 这是正确使用过滤器的方法吗?如何选择ReXxx()函数?Read 24()函数能给我最高的精度吗?或者Read 16()是否足够恰当? 谢谢! 以上来自于百度翻译 以下为原文 Hi Everyone, How do we go about using the new filter component? I would like to try the new filter component as follows: 1) 12 bit data input 2) Basic Hamming window FIR lowpass filter 12 bit sample data conceptual code: //Global variables int16 data[128] = {...};//Some array of input values that I will import from another program int16 output[256];//Empty array that will hold the filter's output (big enough to account for size increase due to convolution) uint16 i;//Counter for main loop void main() { Filter_Start(); for(i = 0; i < 128; i++) { Filter_Write16(data); CyDelay(1);//Be sure that filter has finished its operation output = Filter_Read16(); } //Print the data to the test terminal upon completion } Is this the right way to go about using the filter? How do I choose the Readxx() function? Does the Read24() function give me the highest precision? Or will the Read16() be sufficent and scale properly? Thanks! |
我也对此深感兴趣。我想你可能需要设置一致性寄存器第一。
以上来自于百度翻译 以下为原文 I'm intrested in this too. I think you might have to set the coherency register 1st. Unfortunatley, all of the code examples for this are down right now. |
我用这个代码做了一次尝试,看起来效果不错。
对于(i=0;i & lt;inlln;i++) { /过滤材料 FieldHythRead 16(FieldChhanelyA,输入); CyDelay(1); 输出=FieldRead 16(Fiter); /取滤波器输出并通过USB打印到终端 Simulf(缓冲器,“%d”,输出); UARTH字符串(缓冲器); } 以上来自于百度翻译 以下为原文 I gave it a try with this code, and it seemed to work pretty well. for(i = 0; i < IN_LEN; i++) { //Filter stuff Filter_Write16(Filter_CHANNEL_A, input); CyDelay(1); output = Filter_Read16(Filter_CHANNEL_A); //Take the filter's output and print to terminal via USB sprintf(buffer, "%d,", output); UART_PutString(buffer); } |
741个成员聚集在这个小组
加入小组2002 浏览 1 评论
1761 浏览 1 评论
3545 浏览 1 评论
1696 浏览 6 评论
1466 浏览 1 评论
274浏览 2评论
170浏览 2评论
355浏览 2评论
299浏览 2评论
487浏览 2评论
GMT+8, 2024-9-20 20:35 , Processed in 0.867389 second(s), Total 80, Slave 64 queries .
