大家好
我试图只将从ILA捕获的数据保存到特定文件中。 我从xilinx网站上找到的是 write_hw_ila_data命令 但是,当我打开捕获的数据时(.ila) 似乎它不仅包括数据,还包括所有东西。 例如, 如果ILA正在捕获端口A上的流数据(10'h0~10'hf), 如果ILA正在捕获端口B上的流数据(10'haa~10'hff), 是否可以保存数据A& portA&中的dataB 端口B? 我可以提取吗? 还是有其他选择只选择数据? 谢谢 以上来自于谷歌翻译 以下为原文 Hi all expert I am trying to save only data which is captured from ILA into a specific file. What i found from xilinx web site is write_hw_ila_data command However, when I opened the captured data (.ila) it seems like it include every thing not only data. For example, if ILA is capturing streaming data ( 10'h0 ~ 10'hf) on the portA, also if ILA is capturing streaming data (10'haa ~ 10'hff) on the portB, is it possible to save dataA & dataB in portA & portB? can I extract? or is there any other option to select only data? Thank you |
感谢您对@ vsrunga的评论
我附上了我捕获的ila数据(我删除了一些我不想保存的信号) 对于4096个深度样本,只有一个数据全为零 当我打开文件时,它看起来像上面 我只想要特定数据端口的数据0000到0000 你有没有可能吗? 谢谢 以上来自于谷歌翻译 以下为原文 Thank you for comment @vsrunga I attached my captured ila data (i removed some signal that I don't want to save) There is only one data which is all zero for 4096 depth samples when I open the file, it looks like above I want data 0000 to 0000 only for the specific data port Do you thihk it is possible? Thank you |
2501 浏览 7 评论
2871 浏览 4 评论
2330 浏览 9 评论
3424 浏览 0 评论
2512 浏览 15 评论
2457浏览 1评论
661浏览 1评论
521浏览 1评论
801浏览 0评论
GMT+8, 2025-2-24 23:58 , Processed in 1.418494 second(s), Total 75, Slave 59 queries .
