你好
当使用XSG Hw cosim时,系统仿真的一部分将在硬件上运行,结果将用于整体仿真。 下面链接提供了有关co simulaiton的优点和需求的详细信息 http://courses.cs.tamu.edu/rabi/cpsc489/resources/hw-sw_cosim.html 问候,萨蒂什----------------------------------------------- --- --------------------------------------------请注意 - 如果提供的信息有用,请将答案标记为“接受为解决方案”。给予您认为有用的帖子。感谢.-- ---------------------------- --------------------- ---------------------- 以上来自于谷歌翻译 以下为原文 Hi Part of your system simulation will be run on the hardware when XSG Hw cosim is used and the results are used in your overall simulation. Below link gives details on advantages and need of co simulaiton http://courses.cs.tamu.edu/rabi/cpsc489/resources/hw-sw_cosim.html Regards, Satish ---------------------------------------------------------------------------------------------- Kindly note- Please mark the Answer as "Accept as solution" if information provided is helpful. Give Kudos to a post which you think is helpful. --------------------------------------------------------------------------------------------- |
2511 浏览 7 评论
2880 浏览 4 评论
2337 浏览 9 评论
3430 浏览 0 评论
2518 浏览 15 评论
2627浏览 1评论
671浏览 1评论
536浏览 1评论
822浏览 0评论
GMT+8, 2025-3-7 01:14 , Processed in 1.230622 second(s), Total 42, Slave 37 queries .
