我为我的班级下载了ISE Webpak,我们使用的是Virtex6系列设备。
在家庭下有一个完整的设备列表,但现在只剩下一个(XC6BLX75T)。 我重新安装了ISE,甚至为virtex6重新安装并安装了BSDL文件,但它仍然没有为virtex6显示多个设备。 知道如何解决这个问题吗? 以上来自于谷歌翻译 以下为原文 I download the ISE Webpak for my class and we use Virtex6 family devices. There use to be a whole list of devices under the family, but now there's only one left (XC6BLX75T). I reinstalled ISE and even donwloaded and installed the BSDL files for virtex6, but it still doensn't show more than one device for virtex6. Any idea how to fix this? |
嗨
不确定您使用的是哪个版本的ISE,但每个版本都有安装和发行说明。 有一个表格讨论了Webpack和ISE Design Suite的架构支持,如本文档第18页所示。 http://www.xilinx.com/support/documentation/sw_manuals/xilinx12_4/irn.pdf 你可以看看你正在使用的ISE webpack的irn。 一旦卸载ISE,您是否可以删除安装文件夹中的剩余文件夹(如果有),并尝试再安装一次。 --hs -------------------------------------------------- --------------------------------------------请注意 - 请注明 如果提供的信息有用,请回答“接受为解决方案”。给予您认为有用并回复导向的帖子。感谢K-- -------------------------------------------------- --------------------- 以上来自于谷歌翻译 以下为原文 hi not sure which version of ISE you are using, but there is a installation and release notes for each release. There is a table that talks about architecture support for Webpack and ISE Design Suite as shown in page 18 of this document. http://www.xilinx.com/support/documentation/sw_manuals/xilinx12_4/irn.pdf you can look at the irn of the ISE webpack you are using. also once you uninstall the ISE, can you delete the remaining folders if any in the installation folder and try installing one more time. --hs ---------------------------------------------------------------------------------------------- Kindly note- Please mark the Answer as "Accept as solution" if information provided is helpful. Give Kudos to a post which you think is helpful and reply oriented. ---------------------------------------------------------------------------------------------- |
查看本文档中的表2-1:
http://www.xilinx.com/support/documentation/sw_manuals/xilinx14_7/irn.pdf 对于Webpack,唯一支持的Virtex-6是XC6VLX75T。 要访问其他设备,您至少需要一个ISE Logic Edition许可证。 如果这是针对学校项目的,您应该与您的教授讨论获得许可证的问题。 - Gabor 以上来自于谷歌翻译 以下为原文 Check out table 2-1 in this document: http://www.xilinx.com/support/documentation/sw_manuals/xilinx14_7/irn.pdf For Webpack, the only Virtex-6 supported is XC6VLX75T. To gain access to other devices you would need at least an ISE Logic Edition license. If this is for a school project, you should talk to your professor about obtaining a license. -- Gabor |
2429 浏览 7 评论
2831 浏览 4 评论
2298 浏览 9 评论
3378 浏览 0 评论
2468 浏览 15 评论
1356浏览 1评论
596浏览 1评论
460浏览 1评论
2013浏览 0评论
738浏览 0评论
GMT+8, 2024-12-29 01:24 , Processed in 1.239848 second(s), Total 78, Slave 62 queries .
