我正在尝试在CPLD xc2c64a上实现双稳态多谐振荡器。
我需要这个双稳态多谐振荡器电路来检测三相输入的相序。 结果对A - > B ---> C序列有好处,但对A - > C - > B不是很好。 我已经编写了双稳态mibaibarator的nand门实现的代码。 这是非常简单的代码,但我无法弄清楚为什么它适用于一个序列而不是另一个序列。 以上来自于谷歌翻译 以下为原文 I am trying to implement a bistable multivibrator on the CPLD xc2c64a. I need this bistable multivibrator circuit to detect phase sequence of a 3 phase input. The results a good for the A-->B--->C sequence but not good for the A-->C-->B sequience. I have written the code for the nand gate implementation of the bistable multivibarator. It is very simple code but I cannot figure out why it is working for one sequence and not for the other. |
请查看此文档http://www.orchardpublications.com/9781934404058ex.pdf
谢谢和RegardsBalkrishan ----------------------------------------------- ---------------------------------------------请将帖子标记为 一个答案“接受为解决方案”,以防它有助于解决您的查询。如果一个帖子引导到解决方案,请给予赞誉。 以上来自于谷歌翻译 以下为原文 check this document http://www.orchardpublications.com/9781934404058ex.pdfThanks and Regards Balkrishan -------------------------------------------------------------------------------------------- Please mark the post as an answer "Accept as solution" in case it helped resolve your query. Give kudos in case a post in case it guided to the solution. |
2487 浏览 7 评论
2865 浏览 4 评论
2324 浏览 9 评论
3414 浏览 0 评论
2506 浏览 15 评论
2308浏览 1评论
649浏览 1评论
514浏览 1评论
2061浏览 0评论
790浏览 0评论
GMT+8, 2025-2-11 21:43 , Processed in 1.238435 second(s), Total 77, Slave 61 queries .
