调了好几天了没结果,现在的问题是收到的全是错误的OXff,LSM303_RecvACK()没有应答,地址左移、右移一位都试过,增加延时也尝试过无果,实在是没办法来寻求大神帮助
#include "msp430x22x4.h" #define uchar unsigned char #define uint unsigned int int Byte_Write(uchar SlaveAddress,uchar REG_Address,uchar REG_data); uchar Random_Read(uchar SlaveAddress,uchar REG_Address); #define LSM303A_SlaveAddress 0x30 //定义器件在IIC总线中的从地址,(加速度)根据ALT ADDRESS地址引脚不同修改 0x30(ADDRESS=0) #define LSM303M_SlaveAddress 0x3C //定义器件在IIC总线中的从地址,(磁场)根据ALT ADDRESS地址引脚不同修改 void delayms(uint x) { uint a,b; for(a=x;a>0;a--) for(b=110;b>0;b--); } void main() { WDTCTL = WDTPW + WDTHOLD;//关看门狗定时器 uchar num1,num2; P3SEL &= ~(BIT0+BIT1);//P3.0 P3.1设置为普通IO口 Byte_Write(LSM303A_SlaveAddress,0x20,0x27); delayms(10); //Byte_Write(LSM303M_SlaveAddress,0x02,0x00); // delayms(10); num1=Random_Read(LSM303A_SlaveAddress,0x28); num2=Random_Read(LSM303A_SlaveAddress,0x29); } /************IIC初始化*************** 分析:以P3.0控制SDA,P3.1控制SCL方式编写 连线:P3.0~SDA P3.1~SCL ************************************/ void delay() { ;; } /*=============总线初始化==============*/ void init() { P3DIR |= BIT0+BIT1;//P3.0 P3.1端口方向设置为输出 P3OUT |= BIT1; //SCL=1,时钟线置高 delay(); P3OUT |= BIT0;//SDA=1,数据线置高 delay(); } /*==============启动信号===========*/ void start() { P3OUT |= BIT1; //SCL=1 P3OUT |= BIT0; //SDA=1 delay();//延时时间要大于4.7us P3OUT &= ~BIT0; //SDA=0 delay();//延时时间应大于4us P3OUT &= ~BIT1; //SCL=0 } /*============终止信号==========*/ void stop() { P3OUT |= BIT1; //SCL=1 P3OUT &= ~BIT0; //SDA=0 delay();//延时时间应大于4us P3OUT |= BIT0; //SDA=1 delay();//延时时间应大于4.7us } /*============应答信号=============*/ void Ask() { P3OUT &= ~BIT0; //SDA=0 delay(); P3OUT |= BIT1; //SCL=1 delay();//延时时间应大于4us P3OUT &= ~BIT1; //SCL=0 delay(); } /*=============非应答信号============*/ void NoAsk() { P3OUT |= BIT0; //SDA=1 delay(); P3OUT |= BIT1; //SCL=1 delay();//应大于4us P3OUT &= ~BIT1; //SCL=0 delay(); } /*=============检测是否有应答信号============*/ int LSM303_RecvACK(){ int nTemp=1; _NOP(); _NOP(); P3OUT &=~ BIT1; //时钟置低; delay(); P3OUT |= BIT0; //数据置高 delay(); P3DIR &= ~BIT0;//SDA端口方向改为输入,因为此后要读入数据 P3OUT |= BIT1; //时钟置高 delay(); nTemp = (int)(P3IN&BIT0); //获得SDA数据 P3OUT&= ~BIT1; //时钟置低; return (nTemp); } /*==========写一个字节=================*/ void write_byte(uchar Data) { uchar i;//i用以计算发送的位数 for(i=0;i<8;i++) { P3OUT &= ~BIT1; //SCL=0,SCL为低时,允许数据变化 delay(); if(Data&0x80) P3OUT|= BIT0;//送1位数据 else P3OUT &= ~BIT0; Data<<=1; delay(); P3OUT |= BIT1; //SCL=1,SCL为1时,要求数据稳定,将数据写入内存 delay(); } P3OUT &= ~BIT1; //SCL=0 delay(); //P3OUT |= BIT0; //SDA=1,释放数据线 //delay(); } /*=========读取一个字节========= 在每次SCL由0变1时,读取一位, 读8位,一字节 ==============================*/ uchar read_byte() { uchar i,temp=0; P3OUT &= ~BIT1; //SCL=0 delay(); P3OUT |= BIT0; //SDA=1 delay(); P3DIR &= ~BIT0;//SDA端口方向改为输入,因为此后要读入数据 for(i=0;i<8;i++) { P3OUT |= BIT1; //SCL=1 delay(); temp<<=1; if(P3IN&BIT0) temp|=0x01;//获取P2.0口读回的数 // P3OUT &= ~BIT1; //SCL=0 // delay(); } P3OUT &= ~BIT1; //SCL=0 delay(); // P3DIR |= BIT0; //读完1Byte数据,SDA口方向设置为输出 return temp; } /********写操作*********/ int Byte_Write(uchar SlaveAddress,uchar REG_Address,uchar REG_data) { int ntemp; P3DIR |= BIT0+BIT1;//P3.0 P3.1端口方向设置为输出 start();//启动IIC //ntemp = LSM303_RecvACK(); //if(ntemp) return 0; write_byte(SlaveAddress);//写器件地址,实验板上器件高4位为1010,低3位接了地,最地位为R/W,现在是写,最低位也为0 ntemp = LSM303_RecvACK(); if(ntemp) return 0; Ask(); write_byte(REG_Address);//写数据地址,即欲将该数据存放于何处,address在0~255取值 Ask(); write_byte(REG_data); Ask(); stop(); } /********读操作*********************** 说明:随机读取,程序分析参见操作时序 *************************************/ uchar Random_Read(uchar SlaveAddress,uchar REG_Address) { P3DIR |= BIT0+BIT1;//P3.0 P3.1端口方向设置为输出 uchar Data; start(); write_byte(SlaveAddress);//写器件地址最低位为0 Ask(); write_byte(REG_Address);//广播数据存放的地方 Ask(); //得到应答后开始读数据 start(); write_byte(SlaveAddress+1);//器件地址最低位为read,为1,表明此时24C02将发送数据,MCU接收数据 Ask(); Data=read_byte();//读取数据赋给Data NoAsk(); stop(); return Data; } |
5个回答
RecvACK()中,sda随scl的变化而变化,其他子程序中没有出现这种情况
有没有示波器啊,有示波器可以抓一下波形看一下问题出在那里,只是分析程序的话感觉会想爆脑壳。
用逻辑分析仪看了,其他时序都对就是没有ACK
你的delay();函数是空的,这样的延时时间够么?如果是空函数,会不会被编译器优化掉了?从而没有提供IIC时序足够的延时时间?没有接收到ACK就说明传感器没有正确识别你发送的命令,后面的数据是不会有变化的。
有需要用到电子元器件的,都可以加我聊下,我们做了十几年了,或者你在苦苦寻找的料我们刚好就有,虽然说几率可能很小,但起码还有!给我们一次机会,也给自己一次机会!2355348525
3247个成员聚集在这个小组
加入小组5370 浏览 1 评论
6190 浏览 1 评论
MSP430FR5994 使用库函数 定时器触发AD问题请教
6470 浏览 2 评论
请问怎么把下面51单片机的代码改成msp430 g2 pocket的代码,还有改下时间变成30秒
2519 浏览 1 评论
4982 浏览 1 评论
5259浏览 3评论
6489浏览 2评论
6211浏览 1评论
5391浏览 1评论
4079浏览 0评论
GMT+8, 2025-7-15 09:34 , Processed in 1.781073 second(s), Total 84, Slave 68 queries .
