嗨,大家好,
我使用的是STM32L475 B-L475E-IOT01套件。我的问题是它不会立刻给我传感器值。我想立刻得到温度,湿度,压力,加速度计和陀螺仪。但它一次只给我4个传感器值。例如,我必须注释掉我的传感器代码然后它给了我传感器值,否则当我将代码加载到带有5个传感器代码的套件中时,用户LED不会闪烁。代码中没有错误。我为每个传感器单独运行代码以获取值,它为我提供了值。请帮我解决这个问题。 谢谢 以上来自于谷歌翻译 以下为原文 Hi everyone, I am using STM32L475 B-L475E-IOT01 kit. My problem is that it does not give me sensors values at once. I want to get the temperature, humidity, pressure, accelerometer and gyro at once. But it only gives me 4 sensor values at once. For example, I have to comment out my one of the sensor code then it gives me the sensor values otherwise when I load my code into the kit with 5 sensors code then the user LED is not blinking. There is no error in the code. I run the code for every sensor individually to get the values and it gives me the values. Please help me with this problem. thank you |
嗨,
你应该附上你的代码,甚至更好(对我来说)一个AC6独立项目。很难想象你的意思 '立刻' ,因为I2C通过传感器读取传感器而不是“立刻”。问候 Nyix 以上来自于谷歌翻译 以下为原文 Hi, You should attach your code or even better (for me) an AC6 standalone project. It's hard to imagine what you mean by 'at once' , because I2C reads sensor by sensor and not 'at once'.Kind regards Nyix |
2738 浏览 1 评论
3241 浏览 1 评论
1810 浏览 1 评论
3650 浏览 6 评论
6039 浏览 21 评论
1339浏览 4评论
201浏览 3评论
对H747I-DISCO写程序时将CN2的st-link复用为usart1,再次烧录时无法检测到stlink怎么解决?
353浏览 2评论
STM32G474RE芯片只是串口发个数据就发烫严重是怎么回事?
444浏览 2评论
STM32处理增量式编码器Z信号如何判断中断是正转的还是反向转的?
275浏览 2评论
GMT+8, 2024-12-25 09:13 , Processed in 1.205383 second(s), Total 78, Slave 62 queries .
