您好,我目前正在使用Agilent E8363B网络分析仪。
有没有办法可以使用labview在PC中保存/传输数据(.s2p文件)? 谢谢。 以上来自于谷歌翻译 以下为原文 Hello, I am currently working with an Agilent E8363B network analyzer. Is there any way that I can save/transfer the data(.s2p file) in PC using labview? Thank you. |
3个回答
嗨,谢谢你的帮助。
你有选项2的任何例子,你可以截图并上传到这里吗? 谢谢:) 以上来自于谷歌翻译 以下为原文 Hi, Thanks for your help. Do you have any examples for option 2 you can screenshot and upload it here? Thank you:) |
我在上一篇文章中引用的帮助主题有一个链接(显示“参见示例程序”),该链接显示了该命令的HP BASIC(又名RMB)示例,但我很久没有使用过LabVIEW而我的PC只是 有一个过期的评估版本。 但也许像odanzy这样的人可能有这样的LabVIEW示例或者可以快速组装一个。 O.J.? 以上来自于谷歌翻译 以下为原文 The help topic I referenced in my previous post has a link (that says "See example program") which shows a HP BASIC (a.k.a. RMB) example for that command, but I haven't used LabVIEW in a long time and my PC just has an expired eval version. But perhaps someone like odanzy might have such a LabVIEW example or could quickly assemble one. O.J.? |
嗨,对于PNA,相同的代码可用于通过Labview从ENA 5071B在PC中保存.s2p文件?
如果是这样,请上传屏幕截图。 以上来自于谷歌翻译 以下为原文 Hi, As of for PNA, the same code can be used for saving .s2p file in PC by labview from ENA 5071B ?? if so can you please upload the screen shot for that . |
1333 浏览 0 评论
2397 浏览 1 评论
2216 浏览 1 评论
2086 浏览 5 评论
2974 浏览 3 评论
1231浏览 1评论
782浏览 0评论
1029浏览 0评论
1333浏览 0评论
GMT+8, 2025-1-13 06:52 , Processed in 1.115879 second(s), Total 48, Slave 43 queries .
