我目前正在测试LIS2DH12的冲击检测和测量项目。
我的第一个问题是: 我必须在阈值寄存器中使用哪个缩放因子,以及在读取值中使用哪个缩放因子为+ - 16 g,低功耗模式(LP)。我是否认为他们与众不同? 读数值:192 mg / LSB 阈值寄存器(INT1_THS,INT2_THS):186 mg / LSB 我的下一个问题是关于最大有效范围 我在低功率模式下以5376 Hz测试了最大读数值+ -16 g。 在OUT寄存器内部,我确实在3轴中的一个或两个位置有8位+127或-128位。 这意味着:127 x 0.192 g = 24.384 g 这个值是否仍然正确,因为它比+ - 16g的最大范围高出10%以上? 非常感谢您的帮助! ( Batek.Miroslav â€OE) #out-of-range#lis2dh12 以上来自于谷歌翻译 以下为原文 I'm currently testing the LIS2DH12 for a project concerning shock detection and measurement. My first question is: Which scaling factor do I have to use at the threshold registers and which one at the readout values for +- 16 g, Low Power mode (LP). Do I get this right that they are different? Readout values: 192 mg / LSB Threshold registers (INT1_THS, INT2_THS): 186 mg / LSB My next question is about the maximum valid range I tested the maximum readout values at +-16 g in low power mode at 5376 Hz. Inside the OUT register I do have 8 bit-values of +127 or -128 at one or two out of the 3 axis. That would mean: 127 x 0.192 g = 24.384 g Is this value still correct because it's a bit more than 10 % above the maximum range of +- 16g? Many thanks in advance for your help! ( Batek.Miroslav ‌) #out-of-range #lis2dh12 |
4个回答
你好,
看看我之前的一个问题的答案(它与磁力计有关,但原理是相同的)。 https://community.st.com/thread/40903-lis3mdl-data-interpretation&sharpcomment-157236 长话短说:如数据表中所述,边界得到保证,边界外的值不能保证有意义。 大卫 注意:原始帖子包含大量线程对话,只能迁移到第9级 以上来自于谷歌翻译 以下为原文 Hello, Have a look at this answer to one of my previous question (it is related to a magnetometer, but the principle is the same). https://community.st.com/thread/40903-lis3mdl-data-interpretation&sharpcomment-157236 Long story short: boundaries are guaranteed as stated in the datasheet, the values outside the boundaries are not guaranteed to be meaningful. David Note: the original post contained a large number of threaded conversations and was only able to be migrated to the 9th level |
16g以上的功能无法保证。
输出可以不是线性的,可以逐个变化 以上来自于谷歌翻译 以下为原文 The functionality above the 16g is not guaranteed. The output can be not linear and can vary piece by piece |
嗨大卫,
非常感谢您的回复! 您是直接来自ST支持团队吗?我只是想知道这个Info是否正式有效,因为我想在生产代码中使用该解决方案。 最好的祝福 菲利普 以上来自于谷歌翻译 以下为原文 Hi David, Many thanks for your reply! Are you directly from the ST Support Team? I just wanted to know if this Info is officially valid because I want to use the solution in production Code. Best regards Philipp |
菲利普你好,
我不是ST员工,但是我链接到你的回复是由我写的 Batek.Miroslav ,,谁是ST员工,所以我会考虑这个官员。最好的问候, 大卫 注意:原始帖子包含大量线程对话,只能迁移到第9级 以上来自于谷歌翻译 以下为原文 Hello Phillipp, I am not an ST employee, however, the reply I linked you to was written by Batek.Miroslav ‌, who is an ST employee, so I would consider this official.Best Regards, David Note: the original post contained a large number of threaded conversations and was only able to be migrated to the 9th level |
2831 浏览 1 评论
3270 浏览 1 评论
1844 浏览 1 评论
3694 浏览 6 评论
6100 浏览 21 评论
对H747I-DISCO写程序时将CN2的st-link复用为usart1,再次烧录时无法检测到stlink怎么解决?
395浏览 2评论
STM32G474RE芯片只是串口发个数据就发烫严重是怎么回事?
487浏览 2评论
STM32处理增量式编码器Z信号如何判断中断是正转的还是反向转的?
317浏览 2评论
使用STM32F407VET6的USB2.0功能,发现ctl后芯片无数据返回,是什么原因可能导致的呢?
235浏览 2评论
用STM32G431开发工程,1.50版本的Package包文件无法输出项目工程
339浏览 2评论
GMT+8, 2025-2-4 07:33 , Processed in 0.935214 second(s), Total 48, Slave 43 queries .
