嗨,
如果有Spartan 3系列的路线图或产品生命周期文档,有人可以告诉我吗? 我们目前在现有产品中使用Spartan 3A器件(XC3S50A-4VQG100C)。 我现在处于新设计的早期阶段,改进了原始设计,并在研究市场上是否有更便宜/更好的Xilinx器件后,我注意到Spartan 6系列现在作为“低端”产品和Spartan推向市场 3不再出现在网站上作为产品系列(除汽车级别外)。 这让我有点担心Spartan 3没有在商业上销售,我不确定这是否应该用于新设计? Spartan 6系列QFP封装中最小的器件是XC6SLX4; 然而,当我比较定价时,它的价格是位于相同范围内的Spartan 3设备的两倍(我知道Spartan 6是一款优质设备),因此它不是等价的替代品 如果有人对此有任何建议,将不胜感激 在此先感谢LeeA Smith 以上来自于谷歌翻译 以下为原文 Hi, Can anybody advise me if there is a roadmap or product life document for the Spartan 3 range ? We currently use a Spartan 3A device (XC3S50A-4VQG100C) in an existing product. I am now in the early stages of a new design improving on the original design and after researching into whether there are any cheaper / better Xilinx devices on the market I've noticed that the Spartan 6 range is now marketed as the 'Low End' offering and Spartan 3 no longer appears on the website as a product range (Apart from the automotive grade). This concerns me a little that the Spartan 3 is not being commercially marketed and I'm unsure if this should be used for new designs ? The smallest device in a QFP package from the Spartan 6 range is the XC6SLX4; however when I compare pricing this is twice the price as the Spartan 3 device which is positioned in the same range (I understand the Spartan 6 is a superior device), therefore it's not an equivalent cost alternative If anybody has any advice on this it would be appreciated Thanks in advance Lee A Smith |
4个回答
Xilinx的标准答案:
没有计划的过时。 当产量过低或晶圆厂不再提供该工艺时,器件将停产。 Xilinx给出了上一次购买中断的一年通知,以及上一次购买完成的另一年。 我认为您不会在VQ100包装中找到更新的设备。 我似乎记得只有VQ144是为Spartan 6提供的,所以这也可能是一个电路板空间问题。 展望未来,除非尚未指定的Spartan-7采用QFP,否则它看起来就像它的所有BGA封装。 如果您的产品生命周期足够短,可以处理2年最大通知/终身购买,那么您可能最好坚持使用您拥有的部件。 - Gabor 以上来自于谷歌翻译 以下为原文 The standard answer from Xilinx: There are no planned obsolescences. Devices are discontinued when the volume gets too low or the fab no longer offers the process. Xilinx gives one year notice of discontinuance for last time buys and another year to complete the last time buys. I don't think you'll find a newer device in the VQ100 package. I seem to recall that only the VQ144 is offered for Spartan 6, so this may also be a board space issue. Going forward, unless the yet to be specified Spartan-7 comes in a QFP, it looks like its all BGA packaging. If your product life cycle is short enough to deal with the 2 year max notice / life time buy, then you're probably best off sticking with the part you have. -- Gabor |
L,
我会和您的Xilinx经销商联系。 他们最好建议您需要安全库存(如果有的话),最佳包装件号等。 你肯定想购买大多数其他人购买的相同部件(最好的可用性,最好的价格,长寿)。 您正在使用的S3A部分非常受欢迎。 在某些时候,你需要改进/升级,所以我会在宣布时看看Spartan 7。 S3A / S3E / S3业务非常强大,所以现在考虑这个问题很好。 根据您的学习情况决定何时需要重新考虑这一点。 不要在最后一刻努力回应最后一次购买通知(尽管如果你正确管理它仍然是两年的供应)。 Austin Lesea主要工程师Xilinx San Jose 以上来自于谷歌翻译 以下为原文 l, I would talk to your Xilinx distributor. They would best advise you on need for safety stock (if any), best package part number, etc. You definitely want to be buying the same part most others are buying (best availability, best price, longevity). The S3A part you are using is quite popular. At some point, you will need to improve/upgrade, so I would look at Spartan 7 when it is announced. S3A/S3E/S3 business is robust, so it is good you think about this now. Decide when you will need to revisit this based on what you learn. Do not get caught at the last minute struggling to respond to the last buy notice (although that is still two years of supply if you manage it properly). Austin Lesea Principal Engineer Xilinx San Jose |
你可能想要考虑设计工具的问题。
斯巴达3需要ISE,Spartan 6也是如此。 ISE几年没有工作,最后一个工作的操作系统是Windows 7我认为, 你自己做了什么。 您是否仍然可以访问具有支持ISE的操作系统的替换计算机,例如5年? 以上来自于谷歌翻译 以下为原文 you might want to consider design tools question. Spartan 3 needs ISE, as do Spartan 6. ISE has not been worked on for a few years now, and the last working OS was windows 7 I think, afte that your on your own. will you still have access to replacment computers with an OS that ISE is supported on in say 5 years ? |
我强烈建议将环境转移到受支持的Linux操作系统14.7。
哪个不太可能消失。 然后确保支持,修改等。 Austin Lesea主要工程师Xilinx San Jose 以上来自于谷歌翻译 以下为原文 I strongly suggest moving the enviroment to a supported Linux OS for 14.7. Which is unlikely to ever go away. Support, modifications, etc. then are assured. Austin Lesea Principal Engineer Xilinx San Jose |
2579 浏览 7 评论
2913 浏览 4 评论
2366 浏览 9 评论
3464 浏览 0 评论
2546 浏览 15 评论
3015浏览 1评论
710浏览 1评论
580浏览 1评论
872浏览 0评论
GMT+8, 2025-4-10 11:55 , Processed in 1.818400 second(s), Total 81, Slave 65 queries .
