6个回答
你好
我使用stm8s-discovery评估板。 我的处理器:ST8S105。 工作区:STVD 和Cosmic编译器。 我尝试基于16499.PDF编译我的项目 我收到以下错误: ----------- Project movment_watch - STM8 Cosmic - 配置调试------------- 删除中间文件......完成! ----------- Project movment_watch - STM8 Cosmic - 配置调试------------- 编译main.c ... cxstm8 -itslib -ifwlib + debug -pxp -no -l + mods0 -pp -i''C: Program Files COSMIC CXSTM8_16K Hstm8''-clDebug -coDebug main.c #error cpstm8 C: Program Files COSMIC CXSTM8_16K Hstm8 mods0.h:0 FlexLM无效主机 main.c中: 命令:''cxstm8 -itslib -ifwlib + debug -pxp -no -l + mods0 -pp -i''C: Program Files COSMIC CXSTM8_16K Hstm8''-clDebug -coDebug main.c''失败后,返回值为:1 退出代码= 1。 movment_watch.elf - 3个错误,0个警告 我很乐意接受一个解决方案 以上来自于谷歌翻译 以下为原文 Hello I work with stm8s-discovery evaluation board. My Processor: ST8S105. Workspace: STVD and Cosmic compiler. I try to compile my project based on 16499.PDF and I Receive the following error: ----------- Project movment_watch - STM8 Cosmic - Configuration Debug ------------- Removing intermediate files ... Done! ----------- Project movment_watch - STM8 Cosmic - Configuration Debug ------------- Compiling main.c... cxstm8 -itslib -ifwlib +debug -pxp -no -l +mods0 -pp -i''C:Program FilesCOSMICCXSTM8_16KHstm8'' -clDebug -coDebug main.c #error cpstm8 C:Program FilesCOSMICCXSTM8_16KHstm8mods0.h:0 FlexLM Invalid host main.c: The command: ''cxstm8 -itslib -ifwlib +debug -pxp -no -l +mods0 -pp -i''C:Program FilesCOSMICCXSTM8_16KHstm8'' -clDebug -coDebug main.c '' has failed, the returned value is: 1 exit code=1. movment_watch.elf - 3 error(s), 0 warning(s) I would be happy to accept a solution |
引用:
FlexLM主机无效 FlexLM是许可证管理员 - 不是吗? 您确定已获得Cosmic的正确许可吗? 以上来自于谷歌翻译 以下为原文 Quote: FlexLM Invalid host FlexLM is the licence manager - isn't it? Are you sure you have properly licensed your Cosmic? |
你好
是的,我有执照。 但我想我知道我得到了错误 因为我在计算机上获得了许可证,我尝试在anather计算机上构建项目。 这样做了吗? 以上来自于谷歌翻译 以下为原文 Hi Yes, I have the licence. but I think I know whay I get ERROR it becose I get the licence on my computer and I try to build the project on anather computer. Does that make sence? |
;)您可以这样做,但您可以指定您的网络路径
运行命令regedit并在HKEY_LOCAL_MACHINE> Software> FLEXlm License Manager文件夹中创建新文件: - 值名称:COSMIC_LICENSE_FILE - 价值数据:拥有许可证时的服务器 问候 mozra 以上来自于谷歌翻译 以下为原文 ;) you can do it, but you can specify your network path run the command regedit and in the HKEY_LOCAL_MACHINE>Software>FLEXlm License Manager folder create new file: - Value name: COSMIC_LICENSE_FILE - Value data: your server when you have the license Regards mozra |
mozra说的是真的,但对于你想做的事情来说可能太复杂了:因为无论如何16k许可是免费的,只需要为你想要处理的每台PC请求一个。
问候, 卢卡 以上来自于谷歌翻译 以下为原文 what mozra says is true, but is probably too complex for what you want to do: since the 16k license is free anyway, just request one for every PC you want to work on. Regards, Luca |
2875 浏览 1 评论
3281 浏览 1 评论
1861 浏览 1 评论
3707 浏览 6 评论
6117 浏览 21 评论
对H747I-DISCO写程序时将CN2的st-link复用为usart1,再次烧录时无法检测到stlink怎么解决?
411浏览 2评论
STM32G474RE芯片只是串口发个数据就发烫严重是怎么回事?
510浏览 2评论
STM32处理增量式编码器Z信号如何判断中断是正转的还是反向转的?
334浏览 2评论
使用STM32F407VET6的USB2.0功能,发现ctl后芯片无数据返回,是什么原因可能导致的呢?
246浏览 2评论
用STM32G431开发工程,1.50版本的Package包文件无法输出项目工程
353浏览 2评论
GMT+8, 2025-2-23 07:37 , Processed in 0.970614 second(s), Total 52, Slave 47 queries .
