您好,我们正在构建一个用于机器状态监控的应用程序。为此,我试图找出具有以下规格的适当加速度计:(1)1.5至2 kHz的频率响应,(2)高ODR,越高越好,(3)模拟抗混叠滤波器, (4)至少14位的分辨率。在查看了不同的加速度计之后,我已经将LSM303AH和ISM330DLC归零(我们将只使用acc传感器)。你能否建议两者中哪一个优先于另一个(对于这个特定的应用)?或者,如果这些不合适,请您提出其他选择。
问候, ANKUR #accelerometer #vibration 以上来自于谷歌翻译 以下为原文 Hello, we are building an application for condition monitoring of machines. For this, I am trying to figure out the appropriate accelerometer with the following specs: (1) a frequency response of 1.5 to 2 kHz, (2) a high ODR, higher the better, (3) an analog anti-aliasing filter, and (4) a resolution of at least 14 bits. After looking at different accelerometers, I have zeroed-in on LSM303AH and ISM330DLC (we'll be utilizing only the acc sensor). Can you please suggest which among the two should be preferred over the other (for this particular application)? Or, if these are not the appropriate ones, could you please suggest other options. Regards, Ankur #accelerometer #vibration |
6个回答
我建议使用ISM330DLC,因为它有4kB,工作电压为1.71V至3.6V。
LSM303AH仅具有256平方FIFO,仅适用于1.8V。 以上来自于谷歌翻译 以下为原文 I would suggest to use ISM330DLC because it has 4kB and works from 1.71V to 3.6V. The LSM303AH has only 256-lvele FIFO and works only at 1.8V. |
感谢Miroslav的建议。你也有可能找到
在ISM330DLC中实现了什么样的抗混叠滤波器? 最好的祝福, ANKUR 在太阳,2018年5月6日下午5:53,Miroslav B< st-microelectronics@jiveon.com> 以上来自于谷歌翻译 以下为原文 Thanks Miroslav for your suggestion. Is it also possible for you to find out what kind of anti-aliasing filter is implemented in ISM330DLC? Best regards, Ankur On Sun, May 6, 2018 at 5:53 PM, Miroslav B |
不幸的是,这个孩子的信息无法在论坛上分享。
以上来自于谷歌翻译 以下为原文 Unfortunately, this kid of information cannot be shared on the forum. |
我明白,当然米罗斯拉夫。另外,我正在阅读数据表
ISM330DLC和LSM6DSL它们似乎都大致完全相同 规格。任何想法之间的重大差异是什么 这两个?只是想确保我们选择合适的传感器 我们的申请。 最好的祝福, ANKUR 在2018年5月9日星期三下午12:02,Miroslav B< st-microelectronics@jiveon.com> 以上来自于谷歌翻译 以下为原文 Sure Miroslav, I understand. Also, I was going through the data sheets of ISM330DLC and LSM6DSL and they both seem to have mostly the exact same specifications. Any idea what is the big/important difference(s) between these two? Just want to ensure that we select the appropriate sensor for our application. Best regards, Ankur On Wed, May 9, 2018 at 12:02 PM, Miroslav B |
ISM330DLC和LSM6DSL非常相似。
ISM330DLC适用于工业应用,它没有计步器和手腕倾斜功能。最小值和最大值也保证了几个参数。 ISM330DLC是其中的一部分 http://www.st.com/content/st_com/en/support/resources/product-longevity.html 程序。 我认为对于您的项目来说,ISM330DLC是不错的选择。 以上来自于谷歌翻译 以下为原文 The ISM330DLC and LSM6DSL are very similar. The ISM330DLC is intended for industrial applications, it doesn't have Pedometer and Wrist tilt functionality. Several parameter are also guaranteed by min and max value. The ISM330DLC is part of the http://www.st.com/content/st_com/en/support/resources/product-longevity.html program. I think for your project the ISM330DLC is good choice. |
谢谢Miroslav!
在2018年5月10日星期四下午1:19,Miroslav B< st-microelectronics@jiveon.com> 以上来自于谷歌翻译 以下为原文 Thank you Miroslav! On Thu, May 10, 2018 at 1:19 PM, Miroslav B |
stm32mp157的异核通信的rpmsg_sdb的m4固件和a7驱动该如何编写?
918 浏览 0 评论
stm32f103用freertos对一个采样率为1kHz的传感器,进行采样,数据出差
978 浏览 0 评论
3134 浏览 1 评论
3406 浏览 1 评论
1998 浏览 1 评论
STM32H7打开DCache后,出现了串口接收信息为空的现象,是哪里出了问题?
152浏览 5评论
用NANO STM32F103RBT6的开发板烧录不了是哪里出了问题?
175浏览 5评论
193浏览 5评论
外部中断触发类型为双边沿触发,进入中断回调后有什么办法判断该边沿是上升沿还是下降沿?
230浏览 5评论
STM32L071CBT6低温环境下无法正常工作是什么原因引起的?
176浏览 5评论
GMT+8, 2025-7-6 06:58 , Processed in 0.931050 second(s), Total 90, Slave 73 queries .
