STVD 4.1.4错误(ASM包含文件中的.NOLIST)
以上来自于谷歌翻译 以下为原文 STVD 4.1.4 bug (.NOLIST in ASM include files) |
敬启者,
我发现了最新的STVD版本如何管理ASM包含文件的错误。 附加的archieve包含一个默认项目,我添加了MyInc.inc 该文件仅包含.NOLIST指令和#define。 项目成功构建后,模拟器(以及我的R-Link工具)会发出以下警告: - >警告:删除包含文件最后一行末尾的空白字符 如果我执行代码,则无法单步执行代码... 如果我按照警告的建议,那么项目就无法构建。 问候 EtaPhi PS:一个解决方法显然是删除.NOLIST指令...... 以上来自于谷歌翻译 以下为原文 Dear Sirs, I found a bug in how the latest STVD release manages ASM include files. The attached archieve contains a default project to which I added MyInc.inc This file contains only a .NOLIST directive and a #define. After the project is successfully built, the simulator (and also my R-Link tool) gives this warning: -> warning: remove white-space characters at the end of the last line of the include file If I execute the code, there is no way to single-step through the code... If I do as the warning suggests, the project can't be built. Regards EtaPhi PS: a workaround is obviously to delete .NOLIST directives... |
2732 浏览 1 评论
3241 浏览 1 评论
1810 浏览 1 评论
3650 浏览 6 评论
6038 浏览 21 评论
1339浏览 4评论
200浏览 3评论
对H747I-DISCO写程序时将CN2的st-link复用为usart1,再次烧录时无法检测到stlink怎么解决?
350浏览 2评论
STM32G474RE芯片只是串口发个数据就发烫严重是怎么回事?
442浏览 2评论
STM32处理增量式编码器Z信号如何判断中断是正转的还是反向转的?
273浏览 2评论
GMT+8, 2024-12-23 16:44 , Processed in 0.943463 second(s), Total 43, Slave 38 queries .
