我意外地命名了一个头文件,我把它添加到WorkExplorer的头部分中,并带有“.c”扩展名。我使用内置的右键-gt;重命名函数将扩展名重命名为“.h”。
但是,当尝试构建时,错误 CORTEXM3ARMGCGCUX41FabelCAPENSECOMMON.O:文件未被识别:文件格式未被识别 (被修改的文件被称为CAPSENSECOMMON.H)。 为了解决这个问题(而且它不是很明显),我不得不从项目中删除文件,然后再把它添加进去,这就修复了bug。它是用PSoC 5设备(因此使用代码Southy GCC编译器)。 不是一个大人物,但值得一提的是… 以上来自于百度翻译 以下为原文 I accidently named a header file that I had added into the header section of the Workplace Explorer with a '.c' extension. I used the inbuilt right-click->rename function to rename the extension to '.h'. However when attempting to build, the error .CortexM3ARM_GCC_441ReleaseCapSenseCommon.o: file not recognized: File format not recognized was produced (the changed file was called CapSenseCommon.h). To fix this (and it was not immediately obvious) I had to remove the file from the project and then add it back in, this fixed the bug. It was with a PSoC 5 device (and hence using the Code Soucery GCC compiler). Not a biggy, but worth mentioning... |
谢谢你的错误报告。我会把它放进我们的缺陷跟踪系统。
对于所有阅读此帖子的人,我们高度鼓励您用工具来报告问题。论坛每天进行监控,并采取行动。 罗伯特 以上来自于百度翻译 以下为原文 Thank you for the error report. I will put that into our defect tracking system. To everybody else reading this post, we highly encourage you to report issues you are having with the tools. The forums are monitored daily and action will be taken. Robert |
741个成员聚集在这个小组
加入小组2002 浏览 1 评论
1761 浏览 1 评论
3544 浏览 1 评论
1696 浏览 6 评论
1466 浏览 1 评论
271浏览 2评论
170浏览 2评论
353浏览 2评论
297浏览 2评论
487浏览 2评论
GMT+8, 2024-9-20 09:30 , Processed in 0.894367 second(s), Total 44, Slave 39 queries .
