大家好,
我对LOGiCORE DisplayPort很感兴趣,我需要知道Spartan 6(Or Virtex 6)是否能够在60hz处理4k的输入视频流? 所以基本上我需要验证ifDisplayPort参考设计是否可用于上面提到的任何FPGA! 我非常感谢有关在低价FPGA上接收4k2k60hz视频的可能解决方案的任何信息。 谢谢。 以上来自于谷歌翻译 以下为原文 Hi all, I am interested in LogiCORE DisplayPort and I need to know if Spartan 6 (Or Virtex 6) is capable of handling an input video stream of 4k at 60hz ? SO basically I need to verify if DisplayPort Reference Designs can be used on any of the mentioned FPGAs above ! I would really appreciate any information regarding a possible solution to receive 4k2k60hz videos on low price FPGAs. Thanks. |
嗨@cheahmedtn
检查此链接。 http://www.xilinx.com/support/documentation/ip_documentation/displayport/v3_1/ds802_displayport.pdf 有关价格信息,请联系离您最近的销售/分销商办事处。 http://www.xilinx.com/about/contact.html 谢谢,维杰----------------------------------------------- ---------------------------------------------请将帖子标记为 一个答案“接受为解决方案”,以防它有助于解决您的查询。如果一个帖子引导到解决方案,请给予赞誉。 以上来自于谷歌翻译 以下为原文 Hi @cheahmedtn Check this link. http://www.xilinx.com/support/documentation/ip_documentation/displayport/v3_1/ds802_displayport.pdf For pricing information, please contact your nearest sales/distributor office. http://www.xilinx.com/about/contact.html Thanks,Vijay -------------------------------------------------------------------------------------------- Please mark the post as an answer "Accept as solution" in case it helped resolve your query. Give kudos in case a post in case it guided to the solution. |
嗨@ vijayak,
谢谢你的快速反应。 您提供的文档称“DisplayPort IP可支持1.62 Gb / s,2.7 Gb / s和5.4 Gb / s的标准速率,适用于消费类和专业显示器。当用于高性能7系列设备时,DisplayPort核心可以传输和 以5.4 Gb / s的速度接收。“ 实际上我需要知道是否可以用Spartan 6 OR Virtex 6(非7系列)接收UHD 60 Hz(每通道带宽5.94 Gb / s)。 谢谢。 以上来自于谷歌翻译 以下为原文 Hi @vijayak, Thank you for the quick response. The document you provided says that "DisplayPort IP can support standard rates of 1.62 Gb/s, 2.7 Gb/s and 5.4 Gb/s for consumer and professional displays. When used in high-performance 7 series devices, the DisplayPort core can transmit and receive at 5.4 Gb/s." Actually I need to know if the UHD 60 Hz (Bandwidth Per Channel 5.94 Gb/s) can be received with Spartan 6 OR Virtex 6 (Not 7 series). Thank you. |
2308 浏览 7 评论
2719 浏览 4 评论
2201 浏览 9 评论
3282 浏览 0 评论
2354 浏览 15 评论
633浏览 1评论
1685浏览 1评论
444浏览 1评论
202浏览 1评论
653浏览 0评论
GMT+8, 2024-9-21 22:40 , Processed in 1.351865 second(s), Total 80, Slave 64 queries .
