扫一扫,分享给好友
是否有Xilinx或任何其他实例提供的编码风格指南?
我知道综合指南讲述了如何编写某些结构,但我正在寻找有关过程,信号,流水线信号,项目组织,...的命名约定的指导。 我可以想象Xilinx编写IP代码的人遵循一些指导原则,如果它们可用,那就太棒了。 **如果答案是有帮助的话,那就是kudo。 如果您的问题得到解答,请接受解决方案 以上来自于谷歌翻译 以下为原文 Is there any coding style guideline available from Xilinx or any other instance? I know the synthesis guide tells how to write certain constructs, but I'm looking for guidance on naming conventions for processes, signals, pipelined signals, project organisation, ... I can imagine Xilinx people who code their IP follow some guidelines, it would be great if they are made available. ** kudo if the answer was helpfull. Accept as solution if your question is answered ** |
嗨@ronnywebers
请检查这是否是您要找的。 https://wiki.electroniciens.cnrs.fr/images/Xilinx_HDL_Coding_style.pdf 谢谢,维杰----------------------------------------------- ---------------------------------------------请将帖子标记为 一个答案“接受为解决方案”,以防它有助于解决您的查询。如果一个帖子引导到解决方案,请给予赞誉。 以上来自于谷歌翻译 以下为原文 Hi @ronnywebers Please check if this is what you are looking for. https://wiki.electroniciens.cnrs.fr/images/Xilinx_HDL_Coding_style.pdf Thanks,Vijay -------------------------------------------------------------------------------------------- Please mark the post as an answer "Accept as solution" in case it helped resolve your query. Give kudos in case a post in case it guided to the solution. |
感谢@ vijayak,看起来像文档 - 是否仍然被Xilinx主动使用?
我想让这个帖子保持一段时间,所以人们可能会添加其他建议或来源。 **如果答案是有帮助的话,那就是kudo。 如果您的问题得到解答,请接受解决方案 以上来自于谷歌翻译 以下为原文 thanks @vijayak, that looks like the document - is it still in active use by Xilinx? I'd like to keep this thread open for a short time, so people may add other suggestions or sources. ** kudo if the answer was helpfull. Accept as solution if your question is answered ** |
2474 浏览 7 评论
2860 浏览 4 评论
2321 浏览 9 评论
3406 浏览 0 评论
2502 浏览 15 评论
2169浏览 1评论
645浏览 1评论
506浏览 1评论
2054浏览 0评论
783浏览 0评论
GMT+8, 2025-2-3 13:49 , Processed in 1.149642 second(s), Total 77, Slave 61 queries .
