电子发烧友论坛|
大家好,
如果我把cy768013a(FX2LP)进入我的psoc5系统作为纯粹的编程和调试psoc5集成调试器(同第一次摸包)然后大概FX2LP装置需要一些固件自己。如何获得所需要的固件,以及我如何编程芯片?我需要添加一个社署和使用类似的miniprog3或一个全新的FX2LP是通过它的USB接口从零开始的头?还是我错过了什么,而FX2是一个集成的调试器/程序员已经适用和程序? 以上来自于百度翻译 以下为原文 Hi everyone, If I embed a CY768013A (FX2LP) into my PSoC5 based system purely as an integrated debugger for programming and debugging the PSoC5 (same as on the first touch kits) then presumably the FX2LP device needs some firmware of its own. How do obtain the required firmware, and how do I programm this chip? Do I need to add a header for SWD and use something like the miniprog3 or can a brand new FX2LP be programmed via it's USB interface from scratch? Or have I missed something, and the FX2 comes already suitable and programmed as an integrated debugger/programmer? |
5个回答
默认情况下,FX2LP不带有固件。它可以通过USB或I2C EEPROM编程。
以上来自于百度翻译 以下为原文 FX2LP by default does not come with a firmware. It can programmed through USB or I2C EEPROM. |
肯尼
我正在与我们的软件团队讨论这个问题,开发了FX2LP调试器/程序员。虽然我非常确信你拥有开发自己的PSoC 3程序员所需的所有文档,但是我不能对开发调试器说同样的话。我将更新线程一旦我有关于这方面的信息。 当做, 维韦克 以上来自于百度翻译 以下为原文 Kenny, I am discussing about this with our software team that developed the FX2LP debugger/Programmer. While I am pretty sure that you have all documents it takes to develop your own PSoC 3 Programmer, I cannot say the same thing about developing a Debugger. I will update the thread once I have information on this. Regards, Vivek |
这是不是已经解决了?我希望在我的设计中实现同样的功能。
以上来自于百度翻译 以下为原文 Was this ever resolved? I am looking to implement the same functionality in my design. |
是的,这是可行的。
从我了解到的(我还没有尝试过),FX2在板上没有固件,但是当它首先用程序连接到PC上时,它被下载了(也许它来自工厂编程,但是它可以很容易地更新,而且经常是通过USB)。 以上来自于百度翻译 以下为原文 Yes, it is doable. From what I understand (and I have yet to try this) the FX2 does not have the firmware in it on the boards, but it is downloaded when it is first connected to the PC with Programer on it (well, perhaps it does come from the factory programmed, but it can be updated easily, and often is via USB). |
HTTP://DaveRouthType?COM/FUMU/VIEWTICIC.PHP?F=56和t=3105
以上来自于百度翻译 以下为原文 http://dangerousprototypes.com/forum/viewtopic.php?f=56&t=3105 |
754个成员聚集在这个小组
加入小组2106 浏览 1 评论
1853 浏览 1 评论
3671 浏览 1 评论
1788 浏览 6 评论
1536 浏览 1 评论
572浏览 2评论
424浏览 2评论
438浏览 2评论
386浏览 2评论
916浏览 2评论
GMT+8, 2024-12-25 09:18 , Processed in 0.856607 second(s), Total 51, Slave 46 queries .
