你好,
我希望能够从PL端写入ZYNQ的DDR内存。 异步数据写入FIFO然后在某些时候(当FIFO中有足够的数据时)使用DMA将其传输到Zynq的DDR.Any帮助表示赞赏。 问候,弗雷德 以上来自于谷歌翻译 以下为原文 Hello, I would like to be able write to the ZYNQ's DDR memory from the PL side. The asynchronous data to be written in a FIFO and then at some point (when there is enough data in the FIFO) using DMA to transfer it to Zynq's DDR. Any help is appreciated. Regards, Fred |
3个回答
在zynq上写入ddr就像在ps / pl边界上的某个从端口生成axi事务一样简单。
最简单的配置可能是带有s2mm接口的数据转换器,其中fifo连接到流端,mm端连接到从ps端口。 - 如果提供的信息有用,请将答案标记为“接受为解决方案”。给予您认为有用且回复的帖子。 以上来自于谷歌翻译 以下为原文 Writing to ddr on zynq is as easy as generating axi transactions to one of the slave ports on the ps/pl boundary. The easiest configuration is probably a datamover with s2mm interface where the fifo is connected to the stream side and mm side is connected to the slave ps port.- Please mark the Answer as "Accept as solution" if information provided is helpful. Give Kudos to a post which you think is helpful and reply oriented. |
你好@ muzaffer,
有什么例子我可以看看吗? 问候,弗雷德 以上来自于谷歌翻译 以下为原文 hello @muzaffer, Is there any examples that I can take a look? Regards, Fred |
任何人都可以进一步解释如何从PL端向ZYNQ的DDR内存写入数据吗?
涉及哪个IP? 共享框图将是很好的。要求是当FIFO接近tofull时,需要在ZedBoard上将数据转移到DDR。 以上来自于谷歌翻译 以下为原文 Could anyone explain bit further that how to write data to the ZYNQ's DDR memory from the PL side ? Which IP to involve ? Sharing block diagram would be great. The requirement is when the FIFO is near to full the data need to be transfered to DDR on ZedBoard. |
2488 浏览 7 评论
2865 浏览 4 评论
2324 浏览 9 评论
3415 浏览 0 评论
2506 浏览 15 评论
2326浏览 1评论
650浏览 1评论
515浏览 1评论
2063浏览 0评论
793浏览 0评论
GMT+8, 2025-2-14 00:59 , Processed in 1.385088 second(s), Total 79, Slave 63 queries .
