最近接受一个项目,用的是MSP4305438A sd卡初始化时 程序一直卡死在SD_WaitReady(void)函数中的i = SD_SPI_ReadWriteByte(0XFF)语句中,也就是说一直收不到SPI的应答。函数代码如下:
//等待卡准备好 //返回值:0,准备好了;其他,错误代码 u8 SD_WaitReady(void) { u32 t=0; u8 i = 0; do { i = SD_SPI_ReadWriteByte(0XFF); if(i==0XFF) return 0;//OK t++; }while(t<0XFFFFFF);//等待 return 1; } 硬件上测试过SD卡供电电压是3.05V 且初始化的74个脉冲正常发送出去了。希望做过这块的朋友们给点思路。 |
给你一个调试成功的代码
Uint8 SD_Init(void) { Uint8 time=0; temp = 0; Uint8 Rev_Data[4]={0}; Uint8 pcmd8[] = {0x48,0x00,0x00,0x01,0xAA,0x87}; //CMD8 Uint8 pcmd55[] = {0x77,0x00,0x00,0x00,0x00,0x00}; //CMD55 Uint8 pcmd41[] = {0x69,0x40,0x00,0x00,0x00,0x00}; //CMD41 Uint8 pcmd58[] = {0x7A,0x00,0x00,0x00,0x00,0x00}; //CMD58 P9OUT &= ~BIT0; //打开片选 temp = SD_WriteCmd(pcmd8); //读取卡片版本 if(temp==0x05) { SD_Type =SDV1; //设置卡类型为SD V1.0,如果是V1.0卡,CM8指令后没有后续数据 P9OUT |= BIT0; SD_ReadWriteByte(0xff); //多发8时钟 P9OUT &= ~BIT0; do { temp = SD_WriteCmd(pcmd55); if(temp!=0x01) return temp; temp = SD_WriteCmd(pcmd41); time++; }while((temp!= 0x00)&& (time<200)); P9OUT |= BIT0; }// if(temp==0x05) else if(temp == 0x01) { //V2.0卡,CM8命令后会传回4字节的数据,要跳过再结束本命令 Rev_Data[0] = SD_ReadWriteByte(0xff); //返回0x00 Rev_Data[1] = SD_ReadWriteByte(0xff); //返回0x00 Rev_Data[2] = SD_ReadWriteByte(0xff); //返回0x01 Rev_Data[3] = SD_ReadWriteByte(0xff); //返回0xAA P9OUT |= BIT0; SD_ReadWriteByte(0xff); //多发8时钟 P9OUT &= ~BIT0; do { temp = SD_WriteCmd(pcmd55); if(temp!=0x01) return temp; temp = SD_WriteCmd(pcmd41); time++; if(time>250) return temp; }while(temp!= 0x00); //初始化指令发送完成,接下来获取OCR信息 /*------鉴别SD2.0卡版本--------------*/ temp=SD_WriteCmd(pcmd58); if(temp != 0x00)return temp; //读OCR指令发出后,紧接着是4字节的OCR信息 Rev_Data[0] = SD_ReadWriteByte(0xff); Rev_Data[1] = SD_ReadWriteByte(0xff); Rev_Data[2] = SD_ReadWriteByte(0xff); Rev_Data[3] = SD_ReadWriteByte(0xff); P9OUT |= BIT0; SD_ReadWriteByte(0xff); if(Rev_Data[0] & 0x40) SD_Type = SDHC; else SD_Type =SDV2; }// else if(temp == 0x01) UCB2BR0 = 0x01; //SD为高速 UCB2BR1 = 0x00; return 1; |
2957个成员聚集在这个小组
加入小组2724 浏览 1 评论
MSP430FR5994 使用库函数 定时器触发AD问题请教
3201 浏览 2 评论
请问怎么把下面51单片机的代码改成msp430 g2 pocket的代码,还有改下时间变成30秒
2281 浏览 1 评论
4715 浏览 1 评论
2503 浏览 1 评论
1000浏览 3评论
3201浏览 2评论
2724浏览 1评论
1109浏览 0评论
GMT+8, 2024-9-20 15:22 , Processed in 1.359663 second(s), Total 46, Slave 41 queries .
