3个回答
不。如帖子中所述,它是STARTUP FAILED。
我已阅读应用笔记AN1276,问题确实出现在对齐斜坡和启动斜坡表中。如何为这些函数计算正确的参数/表值?我必须设置哪些其他参数才能使系统正常工作? 以上来自于谷歌翻译 以下为原文 No. As stated in the post, it is STARTUP FAILED. I have read App note AN1276 and the issue does appears to be in the alignment ramp and startup ramp table. How can I compute the correct parameter/table values for these functions? What other parameters must I set to get the system working? |
我收到了ST在线支持的电子表格,它根据PWM频率,极对和转速(rpm / s)计算启动斜坡。我能够在代码中安装新表,现在电机运行正常。
以上来自于谷歌翻译 以下为原文 I received a spreadsheet from ST online support that computes a startup ramp based on PWM freq, pole pairs, and rotational speed (rpm/s). I was able to install the new table in the code and now the motor runs fine. |
2738 浏览 1 评论
3241 浏览 1 评论
1810 浏览 1 评论
3650 浏览 6 评论
6039 浏览 21 评论
1342浏览 4评论
203浏览 3评论
对H747I-DISCO写程序时将CN2的st-link复用为usart1,再次烧录时无法检测到stlink怎么解决?
356浏览 2评论
STM32G474RE芯片只是串口发个数据就发烫严重是怎么回事?
444浏览 2评论
STM32处理增量式编码器Z信号如何判断中断是正转的还是反向转的?
275浏览 2评论
GMT+8, 2024-12-26 01:06 , Processed in 0.920850 second(s), Total 53, Slave 45 queries .
