用AD7792测四线制铂电阻,但是测出来的值一直为0,有没有哪位大佬帮忙看看哪里有问题,谢谢
Resettime=32; CLK_H; CS_L; MOSI_H; while(ResetTime--) //超过连续32个周期为高电平即复位 { CLK_L; delay_us(200); CLK_H; delay_us(200); } delay_us(500); AD7792WriteByte(WriteConfReg); //configuration register AD7792WriteByte(0x12);//单极性,增益Gain 4 AD7792WriteByte(0x90);//internal Reference,带缓冲 while(1) { AD7792WriteByte(WriteIOReg);//IO register AD7792WriteByte(0x03); AD7792WriteByte(WriteModeReg);//Mode Register AD7792WriteByte(0x20);//单次转换 AD7792WriteByte(0x0A);//inter 64 kHZ clock.internal clock is not available at the clk pin. AD7792WriteByte(ReadStateReg);//write to Communication register.The next step is to read from Status register. status = AD7792Read(8); while((status&0x80) == 0x80) //wait for the end of convertion by polling the status register RDY bit { AD7792WriteByte(ReadStateReg);//write to Communication register.The next step is to read from Status register. status = AD7792Read(8); UARTprintf("status:%xn", status); } AD7792WriteByte(ReadDataReg); //write to Communication register.The next step is to read from Data register. AD7792_Data = AD7792Read(16); UARTprintf("V:%dn", AD7792_Data); |
飞凌嵌入式ElfBoard ELF 1板卡-内核空间与用户空间的数据拷贝之数据拷贝介绍
164 浏览 0 评论
飞凌嵌入式ElfBoard ELF 1板卡-字符驱动测试示例
654 浏览 0 评论
虚拟机下ubuntu重启后,进不来图形界面,只能在命令终端,不是因为内部不够的问题,因为已经删过内存了
2027 浏览 0 评论
飞凌嵌入式ElfBoard ELF 1板卡-字符驱动之字符驱动框架描述
1694 浏览 0 评论
飞凌嵌入式ElfBoard ELF 1板卡-开发板适配之USB转网络
478 浏览 0 评论
GMT+8, 2025-3-19 20:18 , Processed in 0.655835 second(s), Total 69, Slave 53 queries .
