您好,当我尝试从Fluke PPC-4读取瞬时压力或怠速或类似情况时,会出现问题。
但是我想设定一个新的目标压力一切都很好。 请查看图片。谢谢,最好的问候。(我使用的是VEE Pro 9.2) 以上来自于谷歌翻译 以下为原文 Hello, When i try to read instant pressure or idn or something like that from Fluke PPC-4 a problem is occured. But I want to set a new target pressure everything is fine. Please check the picture. Thanks in advance, best regards. (I use VEE Pro 9.2) 附件
我已经习惯了RS232 IO,但是我会对此进行一次尝试。当你请求阅读时,你是否应该在命令后面有一个问号...例如'PR?'另外,不确定发送的字节数
事后.....你应该能够删除那些交易,只是在PR? 命令事务,单击EOL ....希望它有所帮助。 以上来自于谷歌翻译 以下为原文 I'm used to RS232 IO, but I'll take a stab at this. When your requesting a reading, should you have a question mark after the command... for example 'PR?' Also, not sure about the bytes sending afterwards..... you should be able to delete those transactions and just on the PR? command transaction, click EOL on.... Hope it helps. |
1385 浏览 0 评论
2419 浏览 1 评论
2268 浏览 1 评论
2105 浏览 5 评论
3020 浏览 3 评论
1432浏览 1评论
827浏览 0评论
1200浏览 0评论
1385浏览 0评论
GMT+8, 2025-2-25 15:03 , Processed in 1.491321 second(s), Total 77, Slave 61 queries .
