你好,
我需要构建一个范围至少为3英寸的电容式接近传感器。 您建议我使用的最佳传感器/控制器是什么?我一直在阅读有关STM8T143的一些信息,但要购买它并不容易。 我需要一些样品来验证它的范围和与我们产品的兼容性。 是否还有ST的其他传感器/控制器用于此任务? 谢谢大家的时间! 以上来自于谷歌翻译 以下为原文 Hello, I need to built a capacitive proximity sensor with a range of at least 3''. What is the best sensor/controller that you advise me to use? I have been reading some things about STM8T143, but it's not easy to buy it. I need some samples to verify it's range and compatibility with our product. Is there any other sensor/controller from ST that is indicated to this task? Thank you all for your time! |
圣保罗
你是对的,你的应用程序的最佳触摸控制器是STM8T143。这种低成本设备非常易于使用。要获取样品,我建议您直接联系当地经销商或ST销售办事处。 或者,您可以使用STM8TL52器件,它是标准的STM8微控制器,带有先进的电容式感应外设。您需要根据ST提供的免费触摸感应库为您的应用开发固件。 最好的祝福, 蒂埃里, 以上来自于谷歌翻译 以下为原文 Paulo, You are right, the best touch controller for your application is the STM8T143. This low cost device is very easy to use. To get samples, I recommend you to directly contact your local distributor or ST sales office. Alternatively, you can use a STM8TL52 device which is a standard STM8 microcontroller with an advanced capacitive sensing peripheral. You will need to develop the firmware for your application based on the free touch sensing library offered by ST. Best Regards, Thierry, |
2783 浏览 1 评论
3252 浏览 1 评论
1826 浏览 1 评论
3672 浏览 6 评论
6065 浏览 21 评论
1349浏览 4评论
对H747I-DISCO写程序时将CN2的st-link复用为usart1,再次烧录时无法检测到stlink怎么解决?
373浏览 2评论
STM32G474RE芯片只是串口发个数据就发烫严重是怎么回事?
470浏览 2评论
STM32处理增量式编码器Z信号如何判断中断是正转的还是反向转的?
294浏览 2评论
使用STM32F407VET6的USB2.0功能,发现ctl后芯片无数据返回,是什么原因可能导致的呢?
217浏览 2评论
GMT+8, 2025-1-13 05:05 , Processed in 1.094218 second(s), Total 76, Slave 60 queries .
