大家好。
在CC模式测试期间,我可以询问安捷伦校准中心在其6035A 500V / 2A 1000W电源上用作负载调节/负载效应的短路开关。您是使用电子开关还是重型机械开关(以创建短路) 电路)从500V @ 2A满载到无负载情况?我没有遇到1000W功率下沉的困难,但我想知道你可以用什么作为短路开关。注意,kz 以上来自于谷歌翻译 以下为原文 Hello all. May I enquire what Agilent calibration centres use as a short circuit switch for Load Regulation/Load Effect on their 6035A 500V/2A 1000W power supplies during CC mode testing. Do you use an electronic switch or a heavy duty mechanical switch (to create a short circuit) to go from 500V @ 2A full load to no load scenario? I have no difficulties sinking the 1000W of power, but I would like to know what you can use as a short circuit switch. Regards, kz |
你好KzHere是一个建议:关闭输出然后在用于创建短路的导线连接后再打开。可以使用开关,但会有一些电弧放电。
还建议使用一个可以接收电流的开关。如果是电子负载,并且负载开关也很短,也可以。我希望这有助于度过美好的一天!你知道强调拼写向后是甜点 ? 甜! 以上来自于谷歌翻译 以下为原文 Hello Kz Here is a recommendation: Turn the output off and then on once the wire used to create the short has been connected. A switch could be used, but there will be some arcing. A switch that will take the current is also recommended. If Electronic loads are uesd and the load has a short on of switch that can be done as well. I hope this helps Have a nice day! Did You Know that stressed spelled backwards is desserts? Sweet! |
1044 浏览 0 评论
2286 浏览 1 评论
2071 浏览 1 评论
1945 浏览 5 评论
2815 浏览 3 评论
808浏览 1评论
594浏览 0评论
690浏览 0评论
2476浏览 0评论
1529浏览 0评论
GMT+8, 2024-9-23 15:28 , Processed in 1.441276 second(s), Total 78, Slave 62 queries .
