扫一扫,分享给好友
你好,
由于PSoC有全速USB,这将是很难接口1MP摄像头。假设1fPS@ 8bit(单色),我们需要1M字节/秒,这对PSoC来说是困难的,所以你必须使用我们的高速外围设备之一。 有很多基于FX2LP的基于相机的设计,不幸的是,我们没有一个参考设计或白皮书,我可以提供。我会检查并让你知道,如果我能够找到一个基于FX2LP的第三方设计。迄今为止,我所看到的设计大多使用CysB.SIS,并在设备和主机端实现自定义协议。 当做, 阿南德 以上来自于百度翻译 以下为原文 Hi, Since PSoC has Full Speed USB it is going to be tough to interface a 1MP Webcam. Assuming 1FPS@8bit(Monochrome), we would require 1M Bytes/Sec, which is tough with PSoC so you'll have to use one of our high-speed peripherals. There are quite a few camera based designs based on FX2LP, unfortunately we don't have a reference design or whitepaper which I can provide. I'll check and let you know if I'm able to find a FX2LP based 3rd party design. The designs that I've seen so far mostly use CyUSB.sys and implement a custom protocol on the device and host side. Regards, Anand |
754个成员聚集在这个小组
加入小组2106 浏览 1 评论
1853 浏览 1 评论
3671 浏览 1 评论
1786 浏览 6 评论
1536 浏览 1 评论
570浏览 2评论
423浏览 2评论
437浏览 2评论
384浏览 2评论
915浏览 2评论
GMT+8, 2024-12-24 08:36 , Processed in 1.014641 second(s), Total 80, Slave 63 queries .
