嗨,
我使用LUT在Virtex-5 FPGA中编写用于环形振荡器的代码(不涉及顺序逻辑)。 我将环形振荡器输出直接连接到FPGA输出LED引脚,观察振荡器上LED的波形。 我观察到环形振荡器的波形是纯模拟信号(如噪声波形),它的频率在20-200MHZ之间。 但是theorticaly Ring Oscillator必须产生Square波形。 所以请帮我看一下LUT的输出波形。 以上来自于谷歌翻译 以下为原文 Hi, I write code in Virtex-5 FPGA for ring oscillator using LUTs (no sequential logic is involved). And I directly connected the ring oscillator output to the FPGA output LED pin and I observe the waveform of LED on osciloscope. And I observe that the waveform of ring oscillator is pure analog singal (like a noise waveform) and it chnages its frequecy between 20-200 MHZ. But theorticaly Ring Oscillator has to produce Square waveform. So please help me regarding the output waveform of LUTs. |
C,
首先,一个可能有12级的环形振荡器可能会以千兆赫兹的速度运行。 更少的阶段,甚至更快。 使用示波器来看这将是一个挑战,因为IO引脚不够快。 在驱动IO引脚之前,使用计数器分割输出。 内部(和外部)的所有东西都是方波,直到目标资源耗尽性能,当信号降级或消失时。 Austin Lesea主要工程师Xilinx San Jose 以上来自于谷歌翻译 以下为原文 c, First of all, a ring oscillator with perhaps 12 stages may run as fast as a gigahertz. Fewer stages, even faster. Looking at that with a scope is going to be a challenge, as the IO pins are not fast enough. Use a counter to divide down the oyutput before you drive the IO pins. Everything is a square wave internally (and externally) until the resouce being targeted runs out of performance, when the signal degrades or disappears. Austin Lesea Principal Engineer Xilinx San Jose |
2708 浏览 7 评论
3024 浏览 4 评论
2441 浏览 9 评论
3557 浏览 0 评论
2642 浏览 15 评论
3442浏览 1评论
852浏览 1评论
707浏览 1评论
GMT+8, 2025-7-19 09:26 , Processed in 1.491177 second(s), Total 75, Slave 59 queries .
