你好Guyz,
只有在Vivado中完成合成之后,我才能估计设计所需的资源。 问题是: 是否可以估计系统生成器(Vivado IDE 2014.3.1)本身的资源? 无法在系统生成器[xilinx blockset / tools]中找到RESOURCE EStiMATOR块,就像它的前身,即系统生成器(ISE)一样。 当我浏览文档时,才知道资源估算器块尚未在系统生成器中引入 - Vivado IDE [如果我错了,请纠正我] 有没有办法[除了在综合后检查利用率报告],这将允许我在算法准备好后立即估算资源 - 作为系统生成器模型? 请指导。 提前致谢。 谢谢& 问候, 专一 以上来自于谷歌翻译 以下为原文 Hi Guyz, I am able to estimate the resource required for a design only after the synthesis is done in the Vivado. The question is: Is it possible to estimate the resource in system generator (Vivado IDE 2014.3.1) itself ? Couldn't find the RESOURCE ESTIMATOR block in the system generator [xilinx blockset/tools] as in its precursor, i.e. System generator (ISE). When i went through the documents, came to know that resource estimator block has not yet been introduced in System generator - Vivado IDE [Please correct me, if i am wrong] Is there any way [other than checking utilization report after synthesis], which will allow me to estimate the resource as soon as the algorithm is ready - as a system generator model ? PLEASE GUIDE. THANKS in advance. Thanks & Regards, Ananya |
4个回答
你好
是的,资源估算器尚未在最新的Vivado Sysgen中提供,您需要查看报告以获取所使用的资源。 问候,萨蒂什----------------------------------------------- --- --------------------------------------------请注意 - 如果提供的信息有用,请将答案标记为“接受为解决方案”。给予您认为有用的帖子。感谢.-- ---------------------------- --------------------- ---------------------- 以上来自于谷歌翻译 以下为原文 Hi Yes the resource estimator is not yet available in latest Vivado Sysgen and you need to see the reports to get the resources used. Regards, Satish ---------------------------------------------------------------------------------------------- Kindly note- Please mark the Answer as "Accept as solution" if information provided is helpful. Give Kudos to a post which you think is helpful. --------------------------------------------------------------------------------------------- |
嗨萨蒂什,
感谢您的快速回复。 我怀疑: 我可以使用ISE找到算法模型的资源估算,然后在Vivado中估算资源吗? [不确定这是否有意义,只是想知道这种方法是否有效] 请建议。 谢谢& 问候, 专一 以上来自于谷歌翻译 以下为原文 Hi Satish, Thanks for the quick reply. My doubt: Can I find the resource estimation for the algorithm model using ISE and then approximate the resource at Vivado ? [Not sure if this makes sense, just wanted to know if this approach works] Please suggest. Thanks & Regards, Ananya |
你好Guyz,
任何人都可以帮助或建议有关资源估算的近似值吗? 提前致谢。 谢谢& 问候, 专一 以上来自于谷歌翻译 以下为原文 Hi Guyz, Can anybody please help or suggest regarding the resource estimation approximation ? Thanks in advance. Thanks & Regards, Ananya |
你好
不确定资源是否匹配, 您可以尝试通过比较系统/实现后的Vivado的利用率报告和ISE资源估算器与您的设计,并根据您可以决定此流程。 问候,萨蒂什----------------------------------------------- --- --------------------------------------------请注意 - 如果提供的信息有用,请将答案标记为“接受为解决方案”。给予您认为有用的帖子。感谢.-- ---------------------------- --------------------- ---------------------- 以上来自于谷歌翻译 以下为原文 Hi Not sure if the resources will match up, You can give it try by comparing the utilization reports of Vivado after sysnthesis/Implementation and the ISE resource estimator with your design and based on that you can decide on this flow. Regards, Satish ---------------------------------------------------------------------------------------------- Kindly note- Please mark the Answer as "Accept as solution" if information provided is helpful. Give Kudos to a post which you think is helpful. --------------------------------------------------------------------------------------------- |
2539 浏览 7 评论
2892 浏览 4 评论
2345 浏览 9 评论
3443 浏览 0 评论
2527 浏览 15 评论
2776浏览 1评论
683浏览 1评论
545浏览 1评论
838浏览 0评论
GMT+8, 2025-3-19 20:07 , Processed in 1.239799 second(s), Total 48, Slave 43 queries .
