首先,我看初始化那里ili9341有很多初始化程序,有LG 2.8” Initial Code, BOE 2.0” INITIAL CODE ,BOE 2.4” INITIAL CODE ,BOE 2.4” INITIAL CODE。。。。TM2.8INCH INITIAL CODE,正点的到底用那个?还有初始化程序中的
LCD_ILI9341_CMD(0xCB); LCD_ILI9341_ Parameter (0x39); 这些应该是调用函数,但是我没有找到原函数, 还有是不是不初始化,屏幕及时接上电也不会亮。 |
你直接用我们提供的例程即可啊。
9341初始化代码: if(lcddev.id==0X9341)//9341初始化 { LCD_WR_REG(0xCF); LCD_WR_DATA(0x00); LCD_WR_DATA(0xC1); LCD_WR_DATA(0X30); LCD_WR_REG(0xED); LCD_WR_DATA(0x64); LCD_WR_DATA(0x03); LCD_WR_DATA(0X12); LCD_WR_DATA(0X81); LCD_WR_REG(0xE8); LCD_WR_DATA(0x85); LCD_WR_DATA(0x10); LCD_WR_DATA(0x7A); LCD_WR_REG(0xCB); LCD_WR_DATA(0x39); LCD_WR_DATA(0x2C); LCD_WR_DATA(0x00); LCD_WR_DATA(0x34); LCD_WR_DATA(0x02); LCD_WR_REG(0xF7); LCD_WR_DATA(0x20); LCD_WR_REG(0xEA); LCD_WR_DATA(0x00); LCD_WR_DATA(0x00); LCD_WR_REG(0xC0); //Power control LCD_WR_DATA(0x1B); //VRH[5:0] LCD_WR_REG(0xC1); //Power control LCD_WR_DATA(0x01); //SAP[2:0];BT[3:0] LCD_WR_REG(0xC5); //VCM control LCD_WR_DATA(0x30); //3F LCD_WR_DATA(0x30); //3C LCD_WR_REG(0xC7); //VCM control2 LCD_WR_DATA(0XB7); LCD_WR_REG(0x36); // Memory Access Control LCD_WR_DATA(0x48); LCD_WR_REG(0x3A); LCD_WR_DATA(0x55); LCD_WR_REG(0xB1); LCD_WR_DATA(0x00); LCD_WR_DATA(0x1A); LCD_WR_REG(0xB6); // Display Function Control LCD_WR_DATA(0x0A); LCD_WR_DATA(0xA2); LCD_WR_REG(0xF2); // 3Gamma Function Disable LCD_WR_DATA(0x00); LCD_WR_REG(0x26); //Gamma curve selected LCD_WR_DATA(0x01); LCD_WR_REG(0xE0); //Set Gamma LCD_WR_DATA(0x0F); LCD_WR_DATA(0x2A); LCD_WR_DATA(0x28); LCD_WR_DATA(0x08); LCD_WR_DATA(0x0E); LCD_WR_DATA(0x08); LCD_WR_DATA(0x54); LCD_WR_DATA(0XA9); LCD_WR_DATA(0x43); LCD_WR_DATA(0x0A); LCD_WR_DATA(0x0F); LCD_WR_DATA(0x00); LCD_WR_DATA(0x00); LCD_WR_DATA(0x00); LCD_WR_DATA(0x00); LCD_WR_REG(0XE1); //Set Gamma LCD_WR_DATA(0x00); LCD_WR_DATA(0x15); LCD_WR_DATA(0x17); LCD_WR_DATA(0x07); LCD_WR_DATA(0x11); LCD_WR_DATA(0x06); LCD_WR_DATA(0x2B); LCD_WR_DATA(0x56); LCD_WR_DATA(0x3C); LCD_WR_DATA(0x05); LCD_WR_DATA(0x10); LCD_WR_DATA(0x0F); LCD_WR_DATA(0x3F); LCD_WR_DATA(0x3F); LCD_WR_DATA(0x0F); LCD_WR_REG(0x2B); LCD_WR_DATA(0x00); LCD_WR_DATA(0x00); LCD_WR_DATA(0x01); LCD_WR_DATA(0x3f); LCD_WR_REG(0x2A); LCD_WR_DATA(0x00); LCD_WR_DATA(0x00); LCD_WR_DATA(0x00); LCD_WR_DATA(0xef); LCD_WR_REG(0x11); //Exit Sleep delay_ms(120); LCD_WR_REG(0x29); //display on } |
3123个成员聚集在这个小组
加入小组3180 浏览 1 评论
MSP430FR5994 使用库函数 定时器触发AD问题请教
4241 浏览 2 评论
请问怎么把下面51单片机的代码改成msp430 g2 pocket的代码,还有改下时间变成30秒
2406 浏览 1 评论
4883 浏览 1 评论
2638 浏览 1 评论
2059浏览 3评论
4242浏览 2评论
3182浏览 1评论
2259浏览 0评论
GMT+8, 2025-3-6 17:42 , Processed in 1.195917 second(s), Total 48, Slave 42 queries .
