嗨,我试图创建一个UART Bootloader为PIC32 MX450F128H使用MPLAB和谐配置器。我配置了驱动程序和设备(附加配置的快照),并生成代码。但是,我不能看到项目中的Bootloader .c文件,它必须由IDE生成。
以上来自于百度翻译 以下为原文 Hi, I am trying to create a UART bootloader for PIC32MX450F128H using MPLAB HARMony Configurator. I configured the drivers and device(snapshots of configuration attached), and generated the code. But, I am not able to see the bootloader.c file in the project, which must get generated by the IDE. Attached Image(s) |
6个回答
嗨,你分享的快照来自MHC配置器。我不认为BootLaoDe.c文件是由这个MHC插件生成的。但是,正如您选择的Bootloader库添加到项目中一样,您可以期望Bootloader。C文件出现在项目树中。您是从头开始创建项目还是使用演示应用程序?并从IDE的属性窗口更改设备?谢谢,
以上来自于百度翻译 以下为原文 Hi, The snapshot you shared are from MHC configurator. I dont think the bootlaoder.c file would be generated by this MHC plugin. However, as you have selected for the bootloader library to be added to the project, you can expect the bootloader.c file to appear into project tree. Are you creating the project from the scratch or using the demo application and changing the device from the properties window of the IDE ? Thanks, |
C将是一个和谐的“库”,你不能编辑它。在你的项目中。他们会给你一组回调来使用。根据和声版本,它们可能并不都是有用的。你看了样例应用程序吗?
以上来自于百度翻译 以下为原文 bootloader.c will be a Harmony "Library" You can not edit it. in you project. They give you a bunch of call backs to use. Depending on the Harmony Version they may not all work. Did you look at the sample Application? |
在Bootloader选项中确定是否选择生成Bootloader链接器脚本?默认是应用程序链接器脚本,并且不会向项目添加Bootloader。
以上来自于百度翻译 以下为原文 Did you make sure in the bootloader options to select generating a bootloader linker script? The default is the application linker script, and the bootloader.c won't be added to the project. |
我从头开始创建这个项目,并希望在引导加载程序栈中做一些小的更改。
以上来自于百度翻译 以下为原文 I am creating the project from scratch and want to do some minor changes in the bootloader stack. |
是的,我选择构建一个BooLoad而不是链接器脚本。
以上来自于百度翻译 以下为原文 Yes, I opted for Build a Bootloader instead of Linker script . |
嗨,我仍然无法生成Bootloader .c文件,但设法从另一个项目中获取它。它由类似的BooTouleSerixIn()和BooLoopeRyTaskS.()组成,项目编译时没有错误。
以上来自于百度翻译 以下为原文 Hi, I was still not able to generate the bootloader.c file but managed to take it from another project. It was consisting the similar Bootloader_Init() and Bootloader_tasks() and the project is compiling without errors. Thanks |
5447 浏览 9 评论
2144 浏览 8 评论
2052 浏览 10 评论
3315 浏览 3 评论
2356 浏览 5 评论
954浏览 1评论
814浏览 1评论
787浏览 1评论
833浏览 0评论
我是Microchip 的代理商,有PIC16F1829T-I/SS 威廉希尔官方网站 问题可以咨询我,微信:A-chip-Ti
529浏览 0评论
GMT+8, 2025-4-19 03:47 , Processed in 1.222702 second(s), Total 85, Slave 69 queries .
