在更改为MPLAB X之后,我使用了真正的ICE上的“切换器”,它用MPLAB X工作得很好。需要返回到MPLAB 8和一个不同的设备(8位)中的一个较老的项目,所以我再次使用了“切换器”。现在真正的ICE在连接到硬件上时找不到我的设备。为了得到设备ID,“真正的冰”进行了所有的测试,包括回路测试。买了一个全新的真正的冰,当然还有一个。我发现FPGA和OS有不同的版本。(见附加屏幕截图)。我怀疑这是一个糟糕的FPGA版本。我怎么才能把一个新的FPGA版本加载到真正的ICE中呢?谢谢你
以上来自于百度翻译 以下为原文 After changing to MPLAB X I used the "Switcher" on the REAL ICE and it worked fine with MPLAB X. Needed to go back to an older project in MPLAB 8 and a different device (8bit) so I used the "Switcher" again. Now the REAL ICE will not find my device when connected to hardware anymore. message is: "Failed to get Device ID" REAL ICE passe all the tests including the Loop back test. (screen shot). Purchased a brand new Real ICE and of course that one work. I found that the FPGA and OS have different versions. (see attached screen shot). I suspect that it is a bad FPGA version. How can I load a new FPGA version into the REAL ICE? Thank you Attached Image(s) |
QHB推荐什么,我已经做过了,但它没有治愈这个问题。但是谢谢你的建议。
以上来自于百度翻译 以下为原文 What qhb recommends, that I already did - and it did not cure the problem. But thanks for the tip. EW |
我接受了RISC的推荐,并手动强制固件更新。最初在MPLAB 8(V892)安装上不起作用。然后,我返回到一个更旧的安装MPLAB 8(V876),在手动强制更新之后,它工作了!所以,现在我有两个真实的。谢谢大家的支持。
以上来自于百度翻译 以下为原文 I took the recommendation from RISC and manually forced the firmware update. That did not work initially on an MPLAB 8 (V8.92) installation. Then, I went back to an even older installation MPLAB 8 (V8.76) and after manually forcing the update - it worked ! So, now I have two REAL-ICE. Thank you all for the support. EW Attached Image(s) |
5451 浏览 9 评论
2149 浏览 8 评论
2053 浏览 10 评论
3316 浏览 3 评论
2356 浏览 5 评论
955浏览 1评论
814浏览 1评论
806浏览 1评论
837浏览 0评论
我是Microchip 的代理商,有PIC16F1829T-I/SS 威廉希尔官方网站 问题可以咨询我,微信:A-chip-Ti
531浏览 0评论
GMT+8, 2025-4-22 10:24 , Processed in 1.754113 second(s), Total 45, Slave 39 queries .
