我正在从事一个老项目(来自MPLAB-8),但现在在MPLAB-X 3.55。它使用C30 VE 3.31工具链,它工作,现在我想尝试,如果改变到XC16将工作。我已经收集到C30不再被保存,所以将来必须使用XC16。但是当我打开Project属性并查看编译器工具链窗格时,我看到了:XC16(没有找到)我在X:StudioMicrochip xC16V1.31文件夹中安装了XC16(我在一周前安装它)。GC30编译器是在C:StudioMicrochip MPLABC30v3.31中,为什么MPLAB-X找不到XC16?????
以上来自于百度翻译 以下为原文 I am working on an older project (from MPLAB-8) but now in MPLAB-X 3.55. It uses the C30 ver 3.31 tool chain. It works and now I want to try if changing to XC16 will work. I have gathered that C30 is no longer maintained so for the future one has to use XC16. But when I open the project properties and look at the Compiler Toolchain pane I see this: XC16 (None found) I do have XC16 installed (I installed it a week ago) in folder C:ProgramsMicrochipxc16v1.31 The working C30 compiler is in C:ProgramsMicrochipmplabc30v3.31 Why does MPLAB-X not find XC16???? |
12个回答
有时你必须“重说”(即……)说服他:)XC16安装在MPLABX窗格的某个地方…
以上来自于百度翻译 以下为原文 Sometimes you have to "re-tell" (i.e. ... convince him :) ) that a XC16 is installed, somewhere in the MPLABX panes... |
我已经查看了我可以想象的每个MPLAB-X角落,我找不到刷新编译器列表的地方…实际上我只看到了在项目属性中列出的编译器(右键单击一个项目并选择属性)。E:在Windows 7启动按钮程序列表中,我可以导航到XC16“文件夹”,只找到“卸载xC16”作为捷径……确实很奇怪。
以上来自于百度翻译 以下为原文 I have looked in every MPLAB-X corner I can imagine and there is nowhere I can find a place to refresh the compiler list... In fact I see the compilers listed only in the project properties (right-click a project and select Properties). But as stated above all I can see is this stupid "Not found". Like this: And in Windows7 Start button Programs list I can navigate to the XC16 "folder" and find only "Uninstall XC16" as a shortcut... Very strange indeed. |
卸载它并重新安装它,所有版本都在MPLAB关闭。
以上来自于百度翻译 以下为原文 Uninstall it and Install it again with All versions on Mplab Closed. |
为了检查我启动了MPLAB 8.84,我的最后一个项目出现了。在MPLAB 8中有菜单项来选择工具套件并设置工具套件的位置。但是XC16 1.31(上星期刚安装的一个)已经在这个环境中存在,而我不需要做任何事情。ST可以通过在语言工具选择框中选择它来切换它。这真的让我吃惊,在这种情况下MPLAB-X如何不知道编译器…卸载和重新安装有什么好处?在MPLAB-X中是否要求编译器安装在“C:程序文件”下面?这是我的系统开发工具中的NO!在MPLAB-X上存储编译器位置的确切位置是什么?编辑:我在我的计算机上查看了注册表,发现:HKEY-CurrTyAuth[SufficeMicrochip LoalGotoOsLxC16]这里写的是XC16的当前位置,所以信息肯定是存在的!为什么MPLAB-X不把它捡起来?
以上来自于百度翻译 以下为原文 In order to check I started MPLAB 8.84 and my last project appeared there. In MPLAB 8 there are menu items to select the tool suite and to set the location of a tool suite. But XC16 1.31 (the one I just installed last week) is already present in this environment without me having to do anything, I just can switch the project to it by selecting it in the language tool selection box. It really beats me how MPLAB-X in such a situation can be unaware of the compiler... What good would uninstalling and re-installing do? Is there a requirement in MPLAB-X that the compiler is installed below "C:Program Files"? That is a no-no in my system for development tools! Where exactly is the compiler locations stored on MPLAB-X? EDIT: I looked in the Registry on my computer and found this: HKEY_CURRENT_USERSoftwareMicrochipLanguageToolsXC16 Here is written the current location of XC16, so the information is for sure present! Why does MPLAB-X not pick it up? |
但是我咬了一下子弹,卸载了我在磁盘上找到的以前的XC16版本(从上星期的2014和1.31中发现了1.21个)。然后我再次安装了1.31个,这次我在安装对话框中检查了“添加XC16到路径”项,这是以前没有检查过的。我不知道这对于MPLAB-X是必要的。结果是MPLAB-X确实识别了安装:但是它也弹出了一个错误对话框,当我点击它时,它打开了一个消息列表:这个“XC16:没有许可证或错误”是什么?我安装了免费版本毕竟…
以上来自于百度翻译 以下为原文 But I bit the bullet and uninstalled both previous XC16 versions I found on my disk (1.21 from 2014 and 1.31 from last week). Then I installed 1.31 again and this time I checked the item "Add XC16 to the PATH" item in the setup dialog, it was unchecked before. I don't know if this is necessary for MPLAB-X... Result afterwards is that MPLAB-X does recognize the installation: But it also pops up an error dialogue, which opens a message list when I click on it: What is this "XC16: Not licensed or error" all about? I installed the FREE version after all... |
如果您正在使用XC16作为免费版本,请尝试安装MPLABX 3.60,在我的情况下,删除了授权NAG消息,出现在3.55
以上来自于百度翻译 以下为原文 If you are using XC16 as free version try installing MPLabX 3.60 In my case that removed the licensing nag messages, which appeared with 3.55 |
谢谢,现在在MPLAB-X 3.60上,不再有任何编译器NAG!我也使用这个建议来升级一个工具(它应该事先说什么工具,但没有)。它原来是关于32位编译器的东西,我无论如何都不使用它。它现在还是被更新了。
以上来自于百度翻译 以下为原文 Thanks, now on MPLAB-X 3.60 and no longer any compiler nag! :) I also used the suggestion to upgrade a tool (it should say beforehand which tool but does not). It turned out to be something concerning the 32 bit compiler, which I don't use anyway. Still it is now updated. |
我认为,Cinzia指的是下面的东西:菜单“工具”&菜单项“选项”&类别“嵌入”&标签“构建工具”,你可以在那里找到一个编译器列表。还有一个按钮“扫描构建工具”。如果一切失败,另一个按钮允许“添加自定义编译器…”。如果没有重新安装,这可能是可行的。
以上来自于百度翻译 以下为原文 I think, Cinzia was referring to the following thing: menu "Tools" > menu entry "Options" > category "Embedded" > tab "Build Tools" You can find a list of compilers there. There is also a button "Scan for Build Tools". And if everything fails another button allows to "Add Custom Compiler ...". Probably that could have worked without re-installation. Attached Image(s) |
以前没有找到它,它看起来像一堆IDE本身的插件,像设置编辑器着色等等。现在我很好,但是在此期间我已经重新安装XC16并安装了一个更新的MPLAB-X。XC16编译器是可见的。:)
以上来自于百度翻译 以下为原文 Did not find it before, it looked to me like a bunch of plug-ins for the IDE itself like setting editor coloring etc. Now I am good, but in the meantime I have reinstalled XC16 and installed a newer MPLAB-X also. The XC16 compiler is visible. :) |
下次发生这种情况时,在安装编译器后,尝试进入“构建工具”,tab moser指出。单击“添加…”并浏览/进入编译器的bin目录IE & lt的路径;无论是G.Microchip xC16V1.30Bin。单击“打开”,然后“OK”。
以上来自于百度翻译 以下为原文 Next time that happens, after installing the compiler try going to the "Build Tools" tab moser pointed out. Click "Add..." and browse to/enter the path to the compiler's bin directory ie Click "Open" and then "OK" |
非常感谢你。这篇文章帮助了me.regards Juergen
以上来自于百度翻译 以下为原文 Thank you verry much. This post helped me. regards Juergen |
另一种工具投票:选项:嵌入式:BuoDooToots!新机器(所以“干净的构建”)…MPLABX,XC32,和声,XC16;它没有识别XC16。扫描建设工具“找到它,现在它是幸福的。
以上来自于百度翻译 以下为原文 Another vote for Tools:Options:Embedded:BuildTools ! New machine (so "clean build")...MPLabX, XC32, Harmony, XC16; and it didn't recognize XC16. "Scan for Build Tools" found it and now it is happy. |
5565 浏览 9 评论
2214 浏览 8 评论
2106 浏览 10 评论
3386 浏览 3 评论
2421 浏览 5 评论
1054浏览 1评论
889浏览 1评论
905浏览 1评论
934浏览 0评论
我是Microchip 的代理商,有PIC16F1829T-I/SS 威廉希尔官方网站 问题可以咨询我,微信:A-chip-Ti
638浏览 0评论
GMT+8, 2025-7-6 04:05 , Processed in 1.544232 second(s), Total 69, Slave 63 queries .
