我对AXI互连有疑问,
1.我的AXI4 Masterwith数据宽度为32位。 我有64位数据宽度的AXI3从器件。互连如何工作? 2.如果我有64位的PL AXI3 Master,我想连接到PS AXI3端口。 互连如何工作? 3.数据增大是否是AXI互连的一部分? 以上来自于谷歌翻译 以下为原文 I have doubts on AXI Interconnect, 1. I have AXI4 Master with data width of 32 bits. I have AXI3 slave with 64 bit data width. How does the interconnect works here?? 2. If i have PL AXI3 Master with 64 bits and i want to connect to PS AXI3 Ports. How does the interconnect works here?? 3. Does data upsizing is a part of AXI interconnect??? |
我对AXI互连有疑问,
1.我的AXI4 Masterwith数据宽度为32位。 我有64位数据宽度的AXI3从器件。互连如何工作? 2.如果我有64位的PL AXI3 Master,我想连接到PS AXI3端口。 互连如何工作? 3.数据增大是否是AXI互连的一部分? 4.我可以直接通过AXI互连将我的AXI3 Master PL自定义代码连接到PS HP端口吗? 请一些身体帮助... 以上来自于谷歌翻译 以下为原文 I have doubts on AXI Interconnect, 1. I have AXI4 Master with data width of 32 bits. I have AXI3 slave with 64 bit data width. How does the interconnect works here?? 2. If i have PL AXI3 Master with 64 bits and i want to connect to PS AXI3 Ports. How does the interconnect works here?? 3. Does data upsizing is a part of AXI interconnect??? 4. Can i connect my AXI3 Master PL custom code to PS HP Ports directly with out AXI Interconnect??? Please some body help on this... |
1.是的,AXI互连包括协议转换器和数据宽度转换器。
您可以查看http://www.xilinx.com/support/documentation/ip_documentation/axi_interconnect/v2_1/pg059-axi-interconnect.pdf2的第5页。 您可以使用从属HP(S_AXI_HP)端口或从属GP端口(S_AXI_GP)3。 AXI Interconnect实现了数据宽度的扩大和缩小。 如果,如上所述,您寻求协议转换和数据宽度转换,那么我建议您使用AXI互连。 以上来自于谷歌翻译 以下为原文 1. Yes, the AXI interconnect includes both a protocol converter and a Data width converter. You can check page 5 of http://www.xilinx.com/support/documentation/ip_documentation/axi_interconnect/v2_1/pg059-axi-interconnect.pdf 2. You can use either a Slave HP (S_AXI_HP) port or a Slave GP port (S_AXI_GP) 3. AXI Interconnect achieves both upsizing and downsizing of data width. 4. If, as above, you seek a protocol conversion and data-width conversion, then I suggest you use AXI Interconnect. |
2552 浏览 7 评论
2899 浏览 4 评论
2350 浏览 9 评论
3448 浏览 0 评论
2535 浏览 15 评论
2902浏览 1评论
694浏览 1评论
554浏览 1评论
851浏览 0评论
GMT+8, 2025-3-28 21:01 , Processed in 1.427715 second(s), Total 78, Slave 62 queries .
