你好,
在STM8S003F3U上根据数据表有1024(总ram) - 513(堆栈)= 510字节用于用户应用:零页面中256字节和Ram部分中的(510-256)= 254。 如果使用短堆栈编译选项,所有数据都会在零页面空间中自动加载,如果我使用超过256个字节,则会出错。 如果我使用长堆栈编译数据自动映射在上部页面:Ram页面,如果使用超过254,我有一个错误(正常,因为有结束堆栈重叠) 我没找到任何stm8的cosmic编译器用户指南。如果我尝试使用pragma强制链接器在不同的空间中设置数据,则错误是:pragma错位... 怎么可能使用混合数据映射零页面和ram页面? 非常感谢 regars 约翰 以上来自于谷歌翻译 以下为原文 Hello, on STM8S003F3U according to datasheet there is 1024(total ram) - 513(stack) = 510 bytes for user application: 256 byte in the zero page and (510-256)= 254 in Ram section. If use the short stack compilation option all data are automaticaly maped in the zero page space and i have an error if i use more than 256 bytes. if i use the long stack compilation data are mapped automaticaly in the upper page: the Ram page and i have an error if use more than 254 (normal because there is the end stack overlap) I did'nt find any cosmic compiler user guide for stm8. If i try to use pragma to force linker to set data in different space the error is : pragma misplaced ... How is it possible to use mixed data mapping zero page and ram page ??? thank's a lot regars johan |
你好,
用户手册与编译器一起安装在/ doc子目录中。 为了将变量放在所需的内存中,首先选择将决定所有变量默认位置的内存模型,然后使用@tiny和@near关键字覆盖所选变量的标准选项: char var1; //将进入页零或16位寻址,具体取决于内存模型 @tiny char var2; //无论内存模型如何,都将进入第0页 @near char var3; //无论内存模型如何,都将进行16位寻址 问候, 卢卡(宇宙) 以上来自于谷歌翻译 以下为原文 Hello, the user manual is installed together with the compiler, in the /doc subdirectory. In order to put your variables in the memory you want, first choose the memory model that will decide where all the variables go by default, and then override the standard choice for selected variables by using the @tiny and @near keywords: char var1; // will go in page zero or 16-bit addressing, depending on the memory model @tiny char var2; // will go in page zero regardless of the memory model @near char var3; // will go in 16 bit addressing regardless of the memory model Regards, Luca (Cosmic) |
2901 浏览 1 评论
3285 浏览 1 评论
1866 浏览 1 评论
3718 浏览 6 评论
6131 浏览 21 评论
对H747I-DISCO写程序时将CN2的st-link复用为usart1,再次烧录时无法检测到stlink怎么解决?
415浏览 2评论
STM32G474RE芯片只是串口发个数据就发烫严重是怎么回事?
515浏览 2评论
STM32处理增量式编码器Z信号如何判断中断是正转的还是反向转的?
342浏览 2评论
使用STM32F407VET6的USB2.0功能,发现ctl后芯片无数据返回,是什么原因可能导致的呢?
248浏览 2评论
用STM32G431开发工程,1.50版本的Package包文件无法输出项目工程
357浏览 2评论
GMT+8, 2025-3-7 06:58 , Processed in 0.919866 second(s), Total 44, Slave 39 queries .
